is it a boost leak ? *pic*
Old Sep 20, 2012 | 07:44 PM
Dynotech Tuning's Avatar
Canexican was having the same problem on his 2.3L only making 13-14psi at redline.
Old Sep 21, 2012 | 01:38 AM
stunt2's Avatar
it is VIII 10.5
Dynotech Tuning, what was the solution ?
Old Sep 21, 2012 | 04:19 AM
domyz's Avatar
First find why your wastegate actuator is opening on a leak test and start from there if this doesn't solve the issue.
Old Sep 21, 2012 | 04:40 AM
stunt2's Avatar
Originally Posted by domyz
What you describe is like your solenoid would not stop air from flowing through WGA.
Maybe it's well connected but the solenoid valve leaks.
Unconnect it and check if the normally close port is leaking with pressure applied.
that's a good starting point
I'll try and do the leak test with ignition on (EBC on), to see what it will give
then I'll try with actuator connected strait to the J pipe nipple
to double check, when leak testing with ignition off/EBC off, its solenoid should no way let the air reach to the actuator ?
Old Sep 21, 2012 | 06:47 AM
domyz's Avatar
I've read on the Profec B and you probably have the normally open port connected to the turbo and the COM port connect to the wastegate. It would be a failsafe installation so: no power -> low boost. When the solenoid valve is activated, it shuts the wastegate port and boost can rise over WGA spring pressure.
After reading that I think that it might be completely normal for the WGA to open when solenoid valve isn't powered (if it's connected like this) .
So like you said, do the boost leak test without solenoid valve installed.
If you are 100% that your profec b is working, lower the "SET" and raise the "GAIN" for high RPM compensation (Maybe you already know how to tune it). If your Evo has no leak, I'd say that you acutally are at max boost with your S2/stroker. The solenoid valve duty cycle is maxed out at 100% and your turbo is too small.
Old Sep 21, 2012 | 09:10 AM
stunt2's Avatar
that's the manual of Profec B SpecII I guess, I have an old Profec B, not specII but connection diagram is same as I see and I have connected it that way. mine doesn't have 'GAIN' button, it has just "wastegate response" sharp/mild adjuster instead of it. dunno if it is the same function
Seancj
Apr 1, 2015 07:12 PM
06h
For Sale - Wheels / Tires
Oct 9, 2012 10:11 PM
Beluga
Northwest Region
Jul 26, 2012 03:36 PM
fit4130bmx
Jun 18, 2012 09:09 PM
