FreeFuel ECU patch - a flex fuel implementation to Evo ECU
Old Mar 6, 2013 | 05:42 AM
  #136
gsxrmel's Avatar
Originally Posted by 99EclipseGSX
That's the difference. Everything else is the same signal/output wise.
hi i also have a 99 gsx and im in the procces to swap the ecu to a evo 8 , at this moment im runing a e85 but im interested in this pach to make a flexfuel.
what is the hardware that i need to make a easy inslatacion ? where i can buy?
thanks a lot
Old Mar 7, 2013 | 01:42 PM
  #137
JustinOlson's Avatar
How is this coming along? I'm very interested in this for my E85 Evo8.
Old Mar 7, 2013 | 02:01 PM
  #138
thebluesky's Avatar
I don't know about everyone else, but the big thing I'm waiting for is inter-operability with the SD patches. Once this happens, the Tephramod will be redundant.
Old Mar 7, 2013 | 05:04 PM
  #139
99EclipseGSX's Avatar
This is tested working on the 2D SD patch (96531706) but the Roadspike SD 2.0 (3D maps) don't seem to work correctly with this patch, at least I have serious issues when trying to start (calculates 170 load during cranking and floods engine). Same ROM without patch at least starts, although that particular ROM I believe is no good, the SD maths seem to be quite far off so I'm not bothering with it anyway.
Beau
Old Mar 8, 2013 | 10:14 AM
  #140
thebluesky's Avatar
Intersting. For some reason I thought this to not have been tested with any SD patch. In that case, I may have to play rather soon. I'm in the middle of converting back to the stock ecu for my new build but may need a few pointers on how to even set up all of these patches.
Old Mar 14, 2013 | 10:11 AM
  #141
ast's Avatar
ast
I bought JDM Evo 9 ECU to eventually do the Evo 9 port. I have been using 3-plug JDM Evo 8 ECU so it should fit pretty easily.
Do I need to mask any Mivec codes when using Evo 9 ECU with non-mivec engine?
Old Mar 14, 2013 | 10:15 AM
  #142
evo8426's Avatar
I came across this in a quick search, it may help you.
http://ceddy.us/h8-ecu-wiki/evo9-in-a-2gevo8/
Old Apr 4, 2013 | 10:50 AM
  #143
MercenaryX2's Avatar
Does anyone know if you choose to use the Zeitronix stuff if you need the sensor and the ECA for the ECU to calculate the content? Or do we just need the sensor with the pigtail running to the ECU?
Old Apr 4, 2013 | 11:15 AM
  #144
You'd need both. The flex fuel sensors output a digital frequency signal which the stock ECU cannot read. The Zeitronix ECA converts that frequency signal into a 0-5v signal that can be run into the ECU.
Old Apr 11, 2013 | 11:31 AM
  #145
batty200's Avatar
Subscribed.
Old Apr 11, 2013 | 03:20 PM
  #146
ExViTermini's Avatar
What would it take to get this 9417 capable?
Old Apr 11, 2013 | 09:00 PM
  #147
limbi's Avatar
wow very interested in this.
it will take our evos to the next gen
Old Apr 12, 2013 | 08:15 PM
  #148
Live4Redline's Avatar
Superb, Thank you sir!
^ The best answer your gonna get.
Old Apr 21, 2013 | 06:42 PM
  #149
Sooo.....this would be awesome..
Old May 6, 2013 | 10:45 AM
  #150
Any more updates?
