tuning help!
Old Sep 21, 2012 | 09:42 PM
Tmosser's Avatar
tuning help!
Well I started tuning my car today on e85 after getting the old tune from the place that tuned it (DB performance) and some reason it will hit boost (aiming for 30psi)
first pull it will be nice, good afr (high 11's, 12.0) hitting right about 30psi.
than ill do another pull, the car will run like crap! itll boost lower and run a rich as F afr (10.0) and lower the lowest my wideband reads is 10. than ill put in the clutch to stop and it will wanna die, go down to 300 rpm or so and either kill or limp up to idle.
can someone PLEASE help me out and tell me what is going on and help me get it running properly!
Old Sep 21, 2012 | 09:59 PM
Tmosser's Avatar
and no a line or anything of that sort didnt pop off. I can turn off car, adjust boost than itll do a pull and same thing.
Old Sep 21, 2012 | 11:16 PM
stunt2's Avatar
is lean spool off ?
Old Sep 22, 2012 | 03:00 AM
HsamehH's Avatar
you probably had some leak in the charge piping after the 30 psi pull.
Old Sep 22, 2012 | 08:37 AM
Tmosser's Avatar
Ill check for leaks but i donno, pretty much everything is zip tied and all the intercooler piping has t bolt clamps
Old Sep 22, 2012 | 08:57 AM
Tmosser's Avatar
and no lean spool starts at 2500 stops at 7000
Old Sep 22, 2012 | 12:28 PM
stunt2's Avatar
turn it off and try that way
Old Sep 22, 2012 | 03:52 PM
Tmosser's Avatar
Well, did a boost leak test found a leak from theturbo to j pipe. Gonna fix that tomorrow, did a couple pulls 3 rd gear ran perfect 30 psi falling (from leak prolly) 12.0 afr. And did a 4th gear pull 25psi falling 11.0 afr BUT didn't go into limp mode!
Hopefully using a little rtv will seal it. I also crushed my bov. So we will see what happens tomorrow, hopefully all goes well.
And lean spool is still on.
Old Sep 23, 2012 | 11:57 AM
Dynotech Tuning's Avatar
RTV is never a boost leak solution IMO.
-Jamie
Old Sep 23, 2012 | 12:58 PM
211Ratsbud's Avatar
The right gasket maker in the right circumstance is appropriate , but are we talking about gobbling it on there?
Old Sep 23, 2012 | 03:13 PM
You will never see an RTV sealant used on any positive pressure application in our shop. It's a band-aid to the actual issue. Flat flanges and metal gaskets. RTV will eventually succumb to the effects of the pressure and environment. Fix it once and you won't need to come back to it. There are enough potential issues in the system to worry about. Band-aiding them just makes the car a basket case over time.
-Jamie
Old Sep 23, 2012 | 04:36 PM
211Ratsbud's Avatar
Can't argue that!
Old Sep 25, 2012 | 02:48 PM
Tmosser's Avatar
Well i was just going to use a thin bead. But found the gasket for $4 so am just going to order a new one!
I couldnt get my undertray off so i said screw it and am waiting till i have more time.
Old Sep 26, 2012 | 10:26 AM
Tmosser's Avatar
This car, lol. Well now its running like crap. Idle is 12/13afr mostly in 12s wot is solid 11. Can the boost leak cause this? Im assuming not the idle but will lean out wot when fixed. Cel came on, idk what for. Disconnected batt let car run for 20 min than cruised. Hasnt came back on. Wot in 3rd afrs will go to 12.0 but every other gear their 11.0ish
Is anyone willing to look at my tune and help me please!!? I can even throw you some money but dont have too much at the moment. I just want a solid car. It used almost 1/4 tank driving 15miles highway ! (on e85) i really want a 15.0 afr at idle/cruise to get better mpgs. I do have mitsulogger right now for logging.
Old Sep 26, 2012 | 10:33 AM
Anarchy99's Avatar
Get the metal gasket from the dealer!
