3D SD Question...
Old Oct 29, 2012 | 06:34 AM
Douglas_Hammon's Avatar
3D SD Question...
Guys,
If I have a perfectly smooth timing map and AFR transition, but my SD map is really "jaggity", could that cause my car to knock or false knock? ...Even if my car runs generally well and I'm hitting target values for the most part on my AFR/Timing maps and there are no jerky jumps?
Thanks,
Doug
Old Oct 29, 2012 | 08:13 PM
211Ratsbud's Avatar
That shouldn't be an issue, with your highly modified from stock setup you're going to have to check the reliability of your knock sensor settings. There's no way around that. It's something I've been dealing with on a stock 2.0 block and cams with springs. With your additional block work its gonna have to be done
DFelton
May 12, 2013 06:35 PM
EvoIXPilot
Apr 20, 2013 04:50 PM
EvoPower81
Dec 22, 2012 06:38 PM
fimer
Evo X Dyno Results
10
Dec 14, 2012 06:06 AM
