SD with open loop tuning
Old Dec 22, 2012 | 06:19 AM
EvoPower81's Avatar
Hey guys . I am tuning SD set to run open loop. Can I disconnect the o2 sensor? Does the o2 sensor have any affiliation with the knock sensor? The reason im asking is because I do have it disconnected and with my logs I am getting no knock but still my timing figures show figures from my low octane ignition map around max torque. This is weird because it should only revert to that map if im experiencing knock. An ideas?
Old Dec 22, 2012 | 09:59 AM
EvoPower81's Avatar
No help from the gurus !!
Old Dec 22, 2012 | 10:24 AM
211Ratsbud's Avatar
What you are experiencing has likely been covered under another idea.. Iat based ign trims ..what rom are you running? Make sure you're not using iat based trims if you're looking for timing map to match timing adv all the time .. Also log timing map too
Also check to see that the FAA bit 10 is disabled
Old Dec 22, 2012 | 10:29 AM
EvoPower81's Avatar
Im using 96531706 ROM. All of my IAT trims are zeroed out
Old Dec 22, 2012 | 10:39 AM
211Ratsbud's Avatar
And FAA but 10?
Have you logged timing map? What load are you logging I have a thread like this search for that there's a ton if answers about load vs timing vs timing map
Old Dec 22, 2012 | 11:50 AM
211Ratsbud's Avatar
Any luck ?
Old Dec 22, 2012 | 12:59 PM
Biggy VIII's Avatar
Keep in mind that also there are boost trims based on iat that will not work correctly, as on SD we have post IC IAT sensor. So they should be disabled on SD.
Old Dec 22, 2012 | 06:38 PM
Dynotech Tuning's Avatar
The boost tables still work the same since MAF IAT is roughly the same as post WOT IAT with most efficient fmic's. it's the idle IAT adjustment that is inaccurate due to exceedingly high MAF IAT readings vs. post FMIC IAT readings.
Granted, WGDC trims have no relation to the OP's question on ignition timing.
The front O2 sensor has no relation to ignition timing, especially after about 100 load even if it was still enabled. Even so, it only has an effect on fuel and not timing.
-Jamie
enash99
Jul 11, 2011 04:10 AM
DCsleeper
May 7, 2008 01:14 PM
johnnyr55
Apr 12, 2008 06:54 PM
Turd Squirter
Dec 7, 2006 05:42 PM
Mad_SB
Jul 13, 2006 05:18 PM
