HKS 272 smooth idle
Old Nov 9, 2012 | 09:40 AM
Gazika's Avatar
HKS 272 smooth idle
recently installed hks cams ,car idles well but i want to know why i dont get that wroom wroom sound ? it makes it sometimes when im braking or just stopped.
Old Nov 9, 2012 | 11:02 AM
STLEVOIX's Avatar
what is the sound you are looking for exactly?
Old Nov 9, 2012 | 11:25 AM
Gazika's Avatar
i mean this sound
Old Nov 9, 2012 | 11:30 AM
sobo's Avatar
From what I understand, cam lope is not something to be desired.
I had the lope on Kelford 272's and afterwards a tune really smoothed my idle back out. I think the lope throws off your idle fuel trims, however I could be wrong.
Old Nov 9, 2012 | 11:46 AM
domyz's Avatar
It's all in the tune, do you have a tactrix cable?
Idle timing, idle rpm and other variables will affect this. This is tunable.
Old Nov 9, 2012 | 11:59 AM
Gazika's Avatar
domyz
sure , i have cable . what changes i have to make in maps ?
Old Nov 9, 2012 | 12:50 PM
211Ratsbud's Avatar
You can add mivec if you have it and lower your timing down to like 4-6 degrees.
Loping definitely makes maf tuning a pita. He'll it even made sd tuning for me a pita
Old Nov 9, 2012 | 01:05 PM
domyz's Avatar
I'm working with him by private messages. He has no MIVEC. He tried 5* idle, 700rpm idle. No lope. We're now working on idling open loop at 15.7 AFR. I'll update.
Old Nov 9, 2012 | 01:15 PM
CurseDSM's Avatar
I would start with HKS cams suck not much better then stock. That basically it. Tune has a bit to play with it too.
Old Nov 9, 2012 | 01:52 PM
Raptord's Avatar
Doesn't nothing really "bad" about the lopping, it's really up to whether the driver wants some or not. I don't see why it'd affect fuel trims.
The only "negative" I can think of is that the car will be a bit rougher when coasting along in first gear at idle in heavy traffic.
Old Nov 9, 2012 | 01:53 PM
todd6027's Avatar
stock cam pulleys ??
Old Nov 9, 2012 | 01:55 PM
todd6027's Avatar
cam lope is very desirable
Old Nov 9, 2012 | 03:29 PM
CurseDSM's Avatar
Lumpy idle would have to do with the lift on the cams. HKS cams have very very low lift which is why they really aren't desired for performance. If you lean out the idle some I am sure it will get there. When I got my car it had hks 272s in it and I thought it had stock cams. Changed to GSC s2 cams and with a little leaner idle lumps good now.
Old Nov 9, 2012 | 03:55 PM
domyz's Avatar
Surely the HKS are not as agressive as the GSCs but there is many VIII out there that have the HKS 272 loping. We'll start by getting his to lope like on other cars.
I agree that if he wants more he has to consider that theses cams won't go further.
Old Nov 9, 2012 | 09:59 PM
CurseDSM's Avatar
Yeah usually lean idle, or they have the 10.8 lift instead of the 10.2 lift.
