load jump from 300 to 10 @WOT ???
Old Nov 22, 2012 | 12:04 PM
stunt2's Avatar
Question load jump from 300 to 10 @WOT ???
can anybody shed some light what does this mean ?
2 byte to 1 byte load factor is set to 1.2 in ecuflash and in evoscan Load 1Byte is 1.2*x as well
using 9653 v7 rom, maps are caled to 350 load
not much boost, 22-23 psi only. NGK 7's and COP
p.s. no stutter, no hesistation
just this
images
Old Nov 22, 2012 | 12:20 PM
dolphin888's Avatar
Are you using Tephra ROM? What's your 2byte to 1byte load factor? If it's left untouched, try increasing it up to 1.5 and don't forget to change that in Evoscan.
Old Nov 22, 2012 | 12:43 PM
stunt2's Avatar
just edited first post
using 9653 v7, maps are scaled to 350 load
load factor is untouched 1.2 in ecuflash and evoscan too
what's the idea of increasing that to 1.5, as I'm barely over 300 load ?
Old Nov 22, 2012 | 12:52 PM
Biggy VIII's Avatar
^^^this
Old Nov 22, 2012 | 12:58 PM
Raptord's Avatar
2byte to 1byte load is too small; increase to 1.4 for example in your map. Make sure you increase to the same value in evoscan as well.
Old Nov 22, 2012 | 01:05 PM
stunt2's Avatar
cheers guys. will try that
Old Nov 22, 2012 | 03:24 PM
dolphin888's Avatar
Increase to 1.5 at least. You don't know how much over 300 you are yet.
Old Nov 22, 2012 | 06:42 PM
Raptord's Avatar
Yes we do. With the regular 1.2 2byte to 1byte factor, the load cap is 306 (255 * 1.2). he saw 19.2 more than 306, which is 325.2. Using 1.3 would be enough, as it's cap is 331.5, however that's cutting it pretty close. So anything over 1.4 would be good.
Old Nov 22, 2012 | 11:36 PM
dolphin888's Avatar
Load can be not so consistent in different runs, as there might be slight condition changes (temp/boost etc...). I have enough experience in this.
Old Nov 23, 2012 | 02:31 AM
stunt2's Avatar
so changed both in evoscan and ecuflash to 1.5 and got wierd high readings and same break in load
below is attached complete log of 4th gear run
upload pics
Old Nov 23, 2012 | 03:14 AM
3K's Avatar
3K
Hmm, don't really know what you did wrong, but you have crazy knock.
Old Nov 23, 2012 | 03:26 AM
dolphin888's Avatar
I am not confused. Look at your log and check out, when you have that break. -> 382.5 <-
Why at his point? Because 255 x 1.5 = 382.5.
You have even bigger load than that.
P.S. Are you running on SD???
Old Nov 23, 2012 | 03:30 AM
stunt2's Avatar
no, I'm on MAF
2.3 with stock 10.5 turbo and S2 cams
p.s. no boost leaks
why such a high load and what to do ?
3K
car is untuned, these are just test runs to collect some data, but can't determine my load yet
Old Nov 23, 2012 | 03:32 AM
dolphin888's Avatar
Anyway try to increase load factor even more. 1.8 maybe.
Old Nov 23, 2012 | 03:34 AM
dolphin888's Avatar
no, I'm on MAF
Are your MAF parameters (maps) untouched?
