From scratch...
Old Dec 9, 2012 | 08:43 PM
ExViTermini's Avatar
From scratch...
If starting from scratch on SD and a larger injector set(like 1000+cc), where do you start?
Can't go based on trims, because the SD settings can alter the trims as well, correct?
TIA
Old Dec 14, 2012 | 09:43 AM
VIIIdriver's Avatar
TIA
Just copy your ignition and fuel maps over to the new rom and use fuel trims to adjust your idle, trims are a great tool to get drivability right, if you use the proper injector scaling and latencies you should be fine, after idle and cruise are tuned then move onto the powerband side of the tune.
Asmodeus6
Jun 9, 2016 09:26 AM
rico05
Aug 14, 2015 10:27 AM
Douglas_Hammon
Aug 24, 2012 06:44 PM
Douglas_Hammon
Aug 16, 2012 07:22 AM
