Help with Cold Start
Hi all,
Around 40 degrees
93
FIC2150
ROM 94171715
Idle is Up/Down then stalls
log atached
Around 40 degrees
93
FIC2150
ROM 94171715
log atached
Under Global ignition settings "Percent Low Temp timing vs Coolant Temp" whats happening is this map is a cold start correction to pull timing to heat up the cats faster. It also makes the car die once on SD. This will fix 95% of your problem. Put all 0's in this map.
thanks, gave it a shot. Still ng. seems a little better though.
attached log
its still pulling timing big time your at 2 degrees then it drops to -13 seems to clearly be a timing/map issue. I would start by zeroing out that low coolant temp timing trim map just above the percent low temp map in ecuflash. Maybe the 9417 rom enables cold start differently.
Still N/G
zeroed out low coolent temp(all - timing values)
also changed periphery bit "enable ignition retard" to 0
Not as much info on this ROM vs 9563
Gonna stick with it, look into iscv stuff.
I find my car runs so much better on 9417
throttle response, light throttle all are very smooth.
thanks again
Hey 3g thanks again for taking a look.
Still N/G
thanks again
Still N/G
thanks again
FYI all,
This thread helped
https://www.evolutionm.net/forums/al...-ones-e85.html
Idle Stepper Look Up modifications are changing behavior
Just some trial and error and s/b good.
This thread helped
