Idle AFR and Cruise AFR rich HELP
Old Jan 4, 2013 | 02:31 PM
10isace's Avatar
Originally Posted by beasters
How do you test the maf? and here is a log that I just did. At first I cruise in 2nd gear at 2500 rpm and then pull over and let it idle. (zip file)
How mechanically/electrically (is that a word) inclined are you? It's in the service manual, so I'll let that explain it. It has the specs in there too.
I'm not sure anyway for me to tell?
You can also check your ROM by opening it up with EcuFlash. Get there and I can get you the rest of the way.
Old Jan 5, 2013 | 08:10 AM
beasters's Avatar
here are two logs in evoscan that i did this morning of STFT (O2 Feedback), AirFlow, Injector Pulse Width, Injector Duty %. Any help or input would be great.. still trying to get down to the bottom of this rich idle. The longer log is of me driving in 4th cruising and then pulling over and idling. The shorter log is just me idling for a couple minutes. Logs are in a zip on rapidshare. http://rapidshare.com/files/3989561819/logs.zip
Old Jan 5, 2013 | 10:57 AM
todd6027's Avatar
what are the low /'mid trims did you recalibrate the wideband sensor for the guage ?
post the rom up
Old Jan 5, 2013 | 11:58 AM
beasters's Avatar
post the rom up
yes I did recalibrate my wideband.
Old Jan 5, 2013 | 12:46 PM
todd6027's Avatar
log the low/mid /high lftf trims , fuel trim in use , o2 sensor feedback, o2 sensor volts, eng warm idling .
Old Jan 11, 2013 | 11:15 AM
beasters's Avatar
I bought another maf and installed it last night and let it idle. It hovered around 14.7 when I first started it and then as it started getting warmed up it stayed at 14.4 like it did before.. I will do an idle log later tonight when I get a chance. Now I really have no idea what the hell could be causing this...
Old Jan 11, 2013 | 11:25 AM
Raptord's Avatar
OP, have you done this?
Old Jan 11, 2013 | 03:23 PM
beasters's Avatar
I will later tonight when i get off work and ill post it up
Old Jan 11, 2013 | 03:24 PM
10isace's Avatar
It may be your WB sensor. BTW, I tried enabling different bits and couldn't get it to idle rich. I'll keep working at it.
Old Jan 11, 2013 | 09:22 PM
beasters's Avatar
I just did this idle log tonight. Any help would be great, thanks.
Old Jan 11, 2013 | 09:32 PM
beasters's Avatar
idk how it could be thought this wideband sensor is only a few months old and I just replace my front o2. I even replaced my maf and nothing has made a difference. I talked to prosport about my wideband maybe being wrong and they said that if it were bad then it would be off my a lot not off by .3-.6 you think I should have them replace it for me anyway?
Old Jan 12, 2013 | 11:05 AM
todd6027's Avatar
what are your inj scaling and latencies / maf scaling
Old Jan 12, 2013 | 11:30 AM
beasters's Avatar
my injector scaling is 513
latency compensation is
4.69 3.312
7.03 1.680
9.38 1.032
11.72 0.672
14.06 0.432
16.41 0.264
18.68 0.144
maf scaling is picture attached
Old Jan 12, 2013 | 12:54 PM
10isace's Avatar
4.69 3.312
7.03 1.680
9.38 1.032
11.72 0.672
14.06 0.432
16.41 0.264
18.68 0.144
Does your MAF Scaling not include the MAF Adder?
Old Jan 13, 2013 | 06:59 AM
beasters's Avatar
no i dont see anything about maf adder
