Serious help please, makes no sense
Hi all,
I got ecuflash (latest) and downloaded the latest version of tephra v7 stock (mods but not speed density etc, the one suggested here https://www.evolutionm.net/forums/ec...hramod-v7.html)
I used EDM/JDM/USDM 96530006 As i have a JDM evo 8.
Before i did anything i read, saved and wrote down my immob codes multiple places. Saved the stock rom etc.
Then flashed the tephramod, successful. But car wont start. No idea why. So i figure, no worries, just revert to stock until i have time to figure it out.
But when i open the stock rom in ECUflash, if the stock rom is selected it WONT LET ME access ANY ECU menu items (read/write/compare etc).
Why wont it let me access these items? Im completely confused. I even downloaded a stock rom and xml from evoscan site but EXACTLY THE SAME PROBLEM wtf is going on here?
yeh i downloaded 1.42 but still, only the READ button is available for me to press. all other ECU buttons are greyed out. This is crazy. It will only let me flash tephramod roms, NOT STOCK. WHY? it makes no sense!
Well this was interesting. The evo 7 base.xml was actually ok. But it seems the roms were loading from another evo 7 base xml file. I couldnt find it so i moved all xml files except the evo7 base one from the folder, then it read the correct xml and allowed me to write to my ecu using it (with the flashmode=mitsukernel).
Very strange. You need to be very careful with the XML files in the directory otherwise crazy stuff happens
thank you very much for the help!
scheides
Oct 22, 2021 08:59 AM
