EcuFlash 1.44 and Mode 23 DoMode Table
Old Jan 18, 2013 | 09:27 AM
Golden's Avatar
There is an Error in the definition files that came with EcuFlash 1.44. They do give credit to me for the definitions (goldenevo.com), but they changed them slightly to use the better bloblist style. That way you don't have to type in values.
In evo10base.xml
This:
Code:
  <scaling name="Mode 23 - DoMode 0x42 -> 0x52" storagetype="bloblist">
    <data name="disabled" value="42" />
    <data name="enabled" value="52" />
  </scaling>
  <scaling name="Mode 23 - DoMode 0x4B -> 0x5B" storagetype="bloblist">
    <data name="disabled" value="4B" />
    <data name="enabled" value="5B" />
  </scaling>
  <scaling name="Mode 23 - DoMode 0x4D -> 0x5D" storagetype="bloblist">
    <data name="disabled" value="4D" />
    <data name="enabled" value="5D" />
  </scaling>
Should be this:
Code:
    <data name="disabled" value="0042" />
    <data name="enabled" value="0052" />
  </scaling>
    <data name="disabled" value="004B" />
    <data name="enabled" value="005B" />
  </scaling>
    <data name="disabled" value="004D" />
    <data name="enabled" value="005D" />
  </scaling>
The 00 byte is very important. The address points to two bytes. The first is always 0. So EcuFlash looks at the 0 byte and expects it to be 4D. It doesn't find 4D and says "No Match". This is a good thing, and it prevents you from bricking your ECU.
Old Jan 18, 2013 | 01:50 PM
Jason S-9's Avatar
Thanks Golden, kind of wish I would of waited to update my Ecuflash now.
Is everyone updating the firmware on there cable as well?
Old Jan 19, 2013 | 12:04 PM
Troy Johnson's Avatar
So we should go in and change the definition file Right?
Old Jan 20, 2013 | 08:12 PM
etay89's Avatar
Fantastic. I haven't updated my ecuflash/evoscan in over a year, I was trying to do mode23 and got stuck..
Then I upgraded and saw it was added and thought sweet...but I didn't flash it. Glad I didn't. Still reading and learning.
Old Jan 20, 2013 | 10:57 PM
evoxsst2009's Avatar
I am using 53050109 and no matter what value i put in either of the mode 23 variable it shows Disabled or no match, never enabled.
what could be the problem.
Thank you.
Old Jan 23, 2013 | 01:55 AM
KingSoft's Avatar
I am using 53050106 and it works, but I have to re-install ECUflash and mod evo10 base file. You can enable by using + or -
Old Jan 23, 2013 | 11:49 AM
MattACK's Avatar
What is the benefit of updating to 1.44?
Old Jan 25, 2013 | 10:21 AM
kozmic27's Avatar
I ditched all the definitions that came with 1.44 because they are formatted differently using inherit base, and I don't want to have to redo all my definitions. If you have a good xml already, you can use it instead of the one that came with the new version.
Old Jan 25, 2013 | 12:31 PM
Jason S-9's Avatar
I think I might do that, I can't seam to get the RAX patch to show up and when they do all I can see is the RAX patch items (everything else disappears)
Old Jan 25, 2013 | 12:53 PM
Drkramm's Avatar
Yea I had the same problem ... Just ended up using my old defs
tephra
Dec 17, 2024 01:36 PM
mrfred
Sep 14, 2022 07:08 PM
tephra
Aug 29, 2021 04:47 AM
mrfred
Sep 17, 2017 06:11 AM
richardjh
Jul 28, 2017 03:49 PM
