I will pay you to fix my cold start issue. Fic 1150/8859
Old Apr 7, 2013 | 05:52 PM
prowakeskater's Avatar
afr is pegged out rich and NO feedback from stft... weird... my wideband is wired into the rear 02... why the hell is the STFT not reading anything
Old Apr 8, 2013 | 04:51 AM
boosted91t's Avatar
Log front oxygen sensor to see if its reading at all and is fluctuating.
Old Apr 8, 2013 | 09:36 AM
raza21_84's Avatar
Sounds like a broken o2 sensor
Old Apr 8, 2013 | 09:06 PM
bonehead move. somehow I saved one of my 8's rom as my original 9's, so 9653 got flashed by accident. It didnt like that much lol.
car no longer stalls or dies but is still off. Warms up full lean at times until I tap the gas, "tricking" it into closed loop.... I'll post a log tomorrow
LTFT for both is zero. after an hour of driving. Ill log volts as well to rule out wrong latencies
Old May 2, 2013 | 06:20 AM
Kakihara's Avatar
if your LTFT stay to zero, does at least your oxygen feedback show something ? if not and your oxygen sensor 1&2 seem to be working then your car must be running in open loop
if oxygen feedback seems to be working and doesnt have bad values, +-25% max I believe (maxing it should throw a CEL tough), someone may have messed up with your "closed loop - lt trim control" table
Old May 24, 2013 | 09:20 AM
thanks! what are the LT values supposed to be?
Old May 24, 2013 | 10:01 AM
Raptord's Avatar
LTFT values vary from -12.5 to 12.5. The closer to 0, the better.
Old May 24, 2013 | 10:26 AM
i mean lt trim control values. I have found resetting them fairs well for WOT consistency
I want my idle to be around 900-950... low to mid, mid to low : mid to high, high to mid ??
Old May 24, 2013 | 10:48 AM
Broke4speed's Avatar
Low/mid: 56.25
Mid/low: 43.75
Mid/high: 1587.50
High/mid: 1581.25
Old May 24, 2013 | 03:08 PM
thats what mine were
im gonna flash a "as close to stock" as possible 88590715 rom for my mods to see if that fixes it. stupid car.
one more thing - is TPS supposed to be at any certain percentage/unit for off throttle/idle? less than 10? 12? I know I messed with my TPS on my throttle body when I did my shaft seals.
Old May 24, 2013 | 03:39 PM
Raptord's Avatar
Roughly between 10-13 is normal I think
Old May 24, 2013 | 03:55 PM
hmm, mine is at 8... wonder if that could be throwing it off
Old May 24, 2013 | 09:36 PM
Raptord's Avatar
No I would think that's fine.
Old May 27, 2013 | 08:21 AM
Kakihara's Avatar
I have no idea how MAP tuning works, I don't have one on my EDM only MAF,
is it normal the MAP sensor values in your "ef this.bin" especially the scaling are completely different from the 88590715 original rom ? They are almost double.
Old Jun 5, 2013 | 03:56 PM
that was scaled for the JDM map sensor.
I fixed the issue by restarting with a stock V7 rom with mods. still have slight idle issues, sometimes i have to blip the throttle to get closed loop to "catch" but it fires and cold starts fine now
thanks guys
pennies_hatchie
68
Mar 5, 2023 08:02 AM
SunnyC
Apr 14, 2020 05:21 PM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Ian0611
50
Jul 6, 2016 11:50 PM
