def 92460000 launch control not functioning
Old Feb 6, 2013 | 07:22 AM
rs_simmo's Avatar
hey guys, logging and mapping via evoscan and 1.3u cable, writing through ecuflash
i cant seem to get launch control to work when writing to ecu, using def 92460000 with the rear o2 delete, the stat rev limit is available through ecuflash, set it to what i want but no good,
is there a line of code i must add to the xml and set through ecuflash (like with the rear o2 delete, to stop CEL)
also, working through evoscan, through the logging screen, how do i get the ignition table up similar to the fuel table, or run through and edit the display, im sure i am missing something simple
thanks
Old Feb 6, 2013 | 01:59 PM
rs_simmo's Avatar
And now the cel is back
Is there a later version that's more accurate ?
Should I be running the above Definition or the 90550001?
E7 jdm gsr
darkmitsu
Lancer Engine Management / Tuning Forums
141
Dec 31, 2022 05:41 AM
mrfred
Feb 26, 2022 06:16 PM
stokEd
51
Oct 14, 2015 06:44 PM
rs_simmo
Mar 18, 2015 07:04 PM
DSMolition
Jul 31, 2014 05:31 AM
