LC-2 to evoscan logging.
Old Jun 12, 2014 | 05:33 AM
DSMolition's Avatar
Can anyone help me get my lc-2 logging on evoscan 2.9? set it up the same as a lc-1?
I had my aem uego working on it but i switched to the lc2. I Have the brown analog wire hooked up to the ecu in the same way i had my aem hooked up(rear o2 if I remember right, pin 75) but can’t get it to log on evoscan.
Can i just log it using thease steps https://www.evolutionm.net/forums/lancer-engine-management-tuning-forums/491918-how-log-your-aem-eugo-evoscan.html
I have been fallowing this for the lc-1 but must be missing something.
https://www.evolutionm.net/forums/ecuflash/337823-how-log-afr-lc-1-w-o-serial-cable.html
Do i have to do this part if i have tephra v7 and can have sim rear o2 selected?
Originally Posted by mrfred
ROM Modifications
My rear O2 sensor simulator code needs to used. This is needed so that the rear O2 ADC input can be made available for the LC-1 analog input. There are two ways to do this. A) tephra has incorporated this code into his latest v5 ROMs, or B) for people who do not want to run his ROM, there are instructions for applying the rear O2 sim patch to either the 88590015 ROM or the 96940011 ROM. There are no current plans to port it to any other ROMs as tephra already has it in his patched ROMs.
Option A - tephra ROM
1) Get a copy of tephra's v5+ ROM, and move all your altered tables over to the tephra ROM.
2) In ECUFlash, find the MUT12 address in the MUT table. If the MUT table is not listed, then it will have to be added to your ECUFlash definition file. A thread listing the MUT table definition for most ROMs is *here*. Change MUT12 to 8409. (You'll have to enter it as 0x8409.) Save the ROM and upload it to your ECU.
Option B - Apply rear O2 sim patch yourself.
1) Patching instructions for the 88590015 ROM are *here*, and l2r99gst has ported my instructions to the 96940011 ROM *here*.
2) Next, choose a new RAM address for the rear O2 ADC input. For the 88590015 ROM, add the following entry to your "88590015.xml" ECUFlash file:
<table name="Rear O2 (ADC 0A) RAM variable" category="Rear_02" address="c2be" type="1D" level="1" scaling="Hex16"/>
For the 96940011 ROM, add the following entry to your "96940011.xml" ECUFlash file:
<table name="Rear O2 (ADC 0A) RAM variable" category="Rear_02" address="a676" type="1D" level="1" scaling="Hex16"/>
Then launch ECUFlash, open the 1D table, and change the value to 8408. (You'll need to enter it as 0x8408.)
3) Next, in ECUFlash, find the MUT12 address in the MUT table. If the MUT table is not listed, then it will have to be added to your ECUFlash definition file. A thread listing the MUT table definition for most ROMs is *here*. Change MUT12 to 8409. (Again, you'll have to enter it as 0x8409.) Save the ROM and upload it to your ECU.
I would just pick up the usb to serial adapter but it says its not compatible for windows 8 and that’s what i have
Any tips or someone to walk me though it would be awesome. It’s been so long since I have messed with evoscan/ecuflash.
Old Jul 30, 2014 | 08:44 PM
osetsky's Avatar
I would like an answer to this before ordering the LC-2. Or have you solved the issue?
http://www.evoxforums.com/forums/sho...d.php?t=146465
Dunno if you saw this, but could help.
Old Jul 31, 2014 | 05:31 AM
DSMolition's Avatar
Yes, I ended up buying a good usb to serial adapter that is compatible with windows 8. I then just used the serial settings on evoscan 2.9 and it works perfect.
It is disappointing however that this WB was revamped and it still uses a serial connection.
This is the adapter that works for me.
Amazon.com: GearMoŽ USB RS-232 Serial Adapter with LED Indicators Win 8 , 7, Vista, XP, 2000 Support: Computers & Accessories Amazon.com: GearMoŽ USB RS-232 Serial Adapter with LED Indicators Win 8 , 7, Vista, XP, 2000 Support: Computers & Accessories
I was just over thinking the situation as i often do.
mrfred
May 1, 2020 10:16 AM
benderrodriguez
Jan 9, 2017 09:10 PM
Spec-Ops1
Vendor Classifieds
21
Sep 27, 2011 10:49 AM
benderrodriguez
May 10, 2010 09:43 AM
black cloud
Feb 13, 2009 03:18 AM
