need help! tuners chime in. new build issues
Whats up guys! Im having idle issues on my brand new build. I have a new built 2.4 with build head and s3's. My problem im having is it dies everytime i push the clutch in over 2k rpms. me n my tuner friend tried everything. The tps is at 16%-99.7% and the iscv seems to be working. Played with all the iscv tables nothing helped. Added timing at idle, still dies, bumped my base pressure to 48, etc it will not catch itself. Anyone have s3's that can help me out?? Btw i have quartermaster twin. Thanks guys its been killing me
Hunter machine assembled my shortblock and i did all the tearing out n building. And it isnt fully tuned yet because i cant even boost im on break in, but my buddy jose usually tunes it
I start to have the same problems but not all the time. At cruising at any speed and i put it in neutral, then the car sometime stall out.
But my main problems is in cold start and after a hard run. Cold start, i have to keep my foot on the gas or else the car idle up and down so low that the car stall out on idle.
But after a hard run, then at a stop it will go up and down between 2000-1400rpm for 15-20seconf then the idle will stay at 1800rpm.
Well let me know how u fix yours so i can fix mine to.
I have the same built like urs. 2.4L block 9:0 manley piston and tt ibeam manley rod, gsc s3 with bc valve spring retainer and also quartermaster twin 6legs clutch.
spadednick88
Feb 21, 2013 06:10 PM
