Newbie dyno graph and logs
Old Feb 26, 2013 | 04:07 PM
WikdEvo's Avatar
I'm new to the datalogging and tuning scene and looking for some constructive criticism.
I made 2 back to back pulls in 3rd gear and put the logs into virtual dyno. These are my results. Does this look scewed or false to any of you guys? I tried to find the flattest road possible.
I'm not for sure where it pulled the afr from because i don't have a wideband. I'm guessing it just pulled the target afr out of the high octane fuel map.
Background on the car. As far as power mods go
2006 WW Evo IX tuned by omar at tampabaytuned. The previous owner said it put down 305 whp. The boost is set at 24# and tapers down at redline.
I don't have an aftermarket map sensor or a wideband just yet and was only doing this to get a feel for the program and datalogging.
Perrin down pipe
Perrin HFC
Tanabe Super medallion cat back
ETS V2 LICP
Perrin intake w/foam filter
Perrin UICP
Grimmspeed MBC
DW300 Fuel pump
PTE 880 injectors
Also, the front tie bar rattles quite a bit on the downpipe and i'm guessing that is where the knock is coming from. Or i'm hoping it is. Is there a way to find out if it is phantom knock or not? Here are 3 logs that i did today.
Here's the link to the google docs where the logs are.
https://docs.google.com/file/d/0B2Bz...it?usp=sharing
quicksilver7
May 11, 2013 02:22 AM
Mike01gsr
17
Apr 17, 2013 06:19 AM
Mike01gsr
18
Apr 17, 2013 06:17 AM
