Need help with Injector Scaling
Old Mar 16, 2013 | 08:55 PM
EvoIXPilot's Avatar
So, I installed FIC 1050 and used Schiedes' numbers:
FIC 1050s
Scaling: 1008
Latencies:
Volts ms
4.69 4.440
7.03 3.192
9.38 1.752
11.72 1.032
14.06 0.840
16.41 0.576
18.68 0.432
After cruising, my LTFT Mids was -1.95 while LTFT Lows 6.25. I lowered the scaling and the exact opposite happened with Mids decreasing to like -7ish, but lows decrease to like 1ish to 0.xx. So, I set it back to 1008 again. Per the big "Injector Scaling and Latency" thread, I should decrease 11.72V which would lower LTFT Lows, but not effect mids?
Old Mar 17, 2013 | 11:42 AM
foxbat's Avatar
Stick with 1008, increase the 0.840 latency a bit, log the trims again then adjust all latencies by the same margin.
Old Mar 17, 2013 | 12:59 PM
EvoIXPilot's Avatar
By the same margin, do u mean increase all from 4.69 to 18.68v?
Old Mar 17, 2013 | 01:02 PM
EvoIXPilot's Avatar
So just changing 14v to. 864 got me.3.125% after 27 mins. Now i should increase all the other volts?
Old Mar 17, 2013 | 01:14 PM
10isace's Avatar
Yes, increase all of them by the same percentage. So if you increased 14v by 5%, then increase the others by 5%.
Old Mar 19, 2013 | 06:40 AM
EvoIXPilot's Avatar
How important is it to get to 0? What does this affect? Right now, my best % are low=3-5% within 30 mins (goes back/forth) and mids=-2 to -4.5% (goes back/forth) within 24 mins. Everytime I tried different setting, it breaks the 5% range to like 7 or 8. I'm using 1008 for scaling. When I change scaling, one trim would be good the other would be wayy off.
Old Mar 19, 2013 | 07:26 AM
evo8426's Avatar
Within 5% is considered acceptable and you can stop where you are at now.
Fast_Freddie
Oct 30, 2023 01:56 AM
ecktt
May 8, 2017 06:18 PM
Raceghost
Nov 28, 2012 04:32 AM
babaz7
Jul 6, 2012 06:35 AM
