EvoScan J2534 Read Error - 16
Old Jun 20, 2013 | 07:20 AM
HsamehH's Avatar
it's because of the latest firmware upgrade. we should talk to tactrix guys not evoscan.
Old Jun 20, 2013 | 07:27 AM
raasfaas's Avatar
Got the same issue going on here...I actually have to walk with both my cables (1.3 and 2.0) since my 1.3 has no trouble reading the codes.
Old Jun 20, 2013 | 09:27 AM
Anubis18's Avatar
Hmm maybe I'll stop at a parts store and have them read the code then... So its the 2.0 that's having the problem reading the DTC Codes..? Or does it have to do with the rom also. I'm also running the same rom the OP has with Tephra V7
Old Aug 13, 2013 | 08:50 AM
dsmmk4's Avatar
Anyone figure this out yet?
Old Aug 14, 2013 | 03:36 AM
Santtuboi's Avatar
Has anyone tried with older evoscan versions? I got same error with 2.9 and op2.0 on evo V. Efi dtc no problem but ayc and abs no go and same error
Old Aug 14, 2013 | 11:55 AM
HsamehH's Avatar
this is Tactrix problem,not evoscan problem. i sent tactrix and didn't get reply.
Old Aug 14, 2013 | 02:20 PM
Grimgrak's Avatar
I tried 2.9 and 2.7 no luck
Old Sep 13, 2013 | 10:29 AM
Dvolution's Avatar
Any updates on this? Got a CEL. J2534 and wont flash a code with Pin 1 and 4 jumped.
Old Oct 7, 2013 | 03:04 PM
4G63John's Avatar
Any news on a fix yet?
Old Oct 7, 2013 | 03:41 PM
mrg7243's Avatar
Mine is doing this too. Cant pull codes or log. Didnt try flashing
Old Oct 26, 2013 | 04:14 PM
AlphaKennyBody's Avatar
BUMP..
I can ECUFlash works no problem, it can Read/Flash in a breeze.
However, on EvoScan... It will log but won't read DTCs, Clear, or Activate the Actuators IE I would test to see if I can get the Rad Fan on HIGH...
I've tested on Both 2.8, 2.9 with my 2.0 Cable.
Old Oct 27, 2013 | 04:54 AM
HsamehH's Avatar
shall someone contact colby ? this happend after ecuflash forced flash my tool.
Old Nov 1, 2013 | 10:14 PM
jrainwater's Avatar
Originally Posted by AlphaKennyBody
BUMP..
This is exactly what is happening to me too. I have an Openport 1.3r that works but it would be nice to pull codes and use the idle speed control actuator with my new Openport 2.0 that I just spent a bunch of money on lol. Anyone figure out this J2534 error 16 issue yet please??????
Old Nov 2, 2013 | 07:18 AM
Broke4speed's Avatar
I'm sure he knows, and I'm sure if he was interested in fixing it...it would be done already.
Old Nov 2, 2013 | 08:27 AM
jrainwater's Avatar
Edit
