EvoScan J2534 Read Error - 16
Old Mar 21, 2013 | 05:18 AM
Smalls's Avatar
Hi guys!
I recently updated to EvoScan v2.9.0023
Since then I have started getting read errors when trying to display DTCs.
I then reinstalled EvoScan 2.8 and have been receiving the same type problems.
The vehicle is a Mitsubishi Evo8
It previously had rom ID: 92660006
Now has Tephra v7 96530706
Engine light has come on after the Tephra mod. and that's the reason I need to check DTCs on it.
Code:
Log from EvoScan:
Info: OpenPort 2.0 Found.
Info: OpenPort Firmware v1.12.368
Info: Battery 13.267V
Info: Initialize Vehicle ECU...
Info: OBDII Connecting...
Info: Waiting for vehicle ecu...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Connecting...
Info: Battery 13.245V
Info: J2534 Read Error - 16
Info: Check DTCs Complete.
Diagnostic trouble codes:
The similar errors have been shown on two other Evos as well the last couple of days. One other Evo8 and a Evo9. I haven't been able to check DTCs at all consistantly, since the update.
Before recently, I haven't had any problems reading DTCs with EvoScan since I started using it 3-4 years ago. Have I missed configurating something?
Old Mar 21, 2013 | 05:21 AM
Smalls's Avatar
Forgot one very important addition to my post above:
I have no problems at all with the scanning/logging features.
It's only the "Display DTC's" that is causing an issue.
Old Mar 22, 2013 | 03:12 PM
rictrd's Avatar
I'm having the same issue "J2534 Read Error - 16" and it doesn't dataloggs...
Old Mar 25, 2013 | 10:49 AM
ifur's Avatar
i've had a similar issue since update, said something about updating firmware and nothing but problems since, i've been in contact with tactrix about what could be the issue
try uninstalling ecuflash and the open port drivers and reinstalling
Old Mar 26, 2013 | 03:11 PM
rictrd's Avatar
Any fixes for this?
Old Mar 26, 2013 | 05:00 PM
rictrd's Avatar
Now I'm getting another error:
Error: Arithmetic operation resulted in an overflow.
Info: Datalogger Ended.
Anyone can help?
Old Apr 1, 2013 | 06:12 PM
andrewzaragoza's Avatar
any update on this.
Old Apr 5, 2013 | 07:24 PM
AKW89's Avatar
I found this: http://www.tactrix.com/index.php?opt...d=38&Itemid=61
Old May 2, 2013 | 08:14 PM
kailoma679's Avatar
Any updates on this error code? Ive got the same problem.....
Old May 19, 2013 | 12:58 PM
dtrackstar's Avatar
any updates?
Old May 19, 2013 | 01:45 PM
Terror Rising's Avatar
I get the same error on DTCs and when trying to use gauge displays. Would love to hear any resolution to this.
Old May 26, 2013 | 07:08 PM
dsmmk4's Avatar
Same issue for me on dtc scan for my evo 8. No problems with logging or anything at all. Im new to evoscan, just downloaded yesterday. I tried to clear cel and it said error but after a min or so cel went off so its working just throwing that error. Maybe a dumb question but does anyone elses abs light flash while logging?
Old May 26, 2013 | 10:43 PM
HsamehH's Avatar
i had exactly the same problems after the new tactrix(force) firmware update.
sometimes it reads dtc but most of the time no. and also i am not able to log injectors duty cycle anymore.
Old May 26, 2013 | 10:46 PM
Santtuboi's Avatar
Same problem here, efi dtc read works normal. Abs dtc sometimes and ayc never. Using Openport 2.0 on Evo V
Old Jun 19, 2013 | 06:21 PM
Anubis18's Avatar
Anyone find a cure?
