V2.9 evoscan shift data to left into logging note header is normal
Old May 14, 2013 | 04:21 AM
  #31
211Ratsbud's Avatar
Secondhand ecu made no change
Old May 14, 2013 | 06:04 AM
  #32
LGshow19's Avatar
That weird.... did you fry any wires? Your software/files?
Old May 14, 2013 | 06:15 AM
  #33
211Ratsbud's Avatar
I noticed the graph viewer on evoscan displays the correct data . Either OO just started hating on csv ? Must be a setting there that got changed I have yet to fugure out
Old May 14, 2013 | 06:36 AM
  #34
LGshow19's Avatar
Didnt you uninstall and install evoscan? If so, did you delete all the evoscan files as well before install?
Old May 14, 2013 | 06:54 AM
  #35
Raptord's Avatar
Can you post a screenshot?
Old May 14, 2013 | 07:56 AM
  #36
211Ratsbud's Avatar
No changes were made to my laptop when this happened. My tuning laptop doesn't even connect to the web. My spare laptop which also has tuning abilities does, suffers same issue. Ill certainly post a screen shot after work
Old May 14, 2013 | 08:16 AM
  #37
PureDrivePerformance's Avatar
Rats
I've had this happen temporarily to some customers. It was just a matter of closing and reopening after making changes in EvoScan, reinstalling or going into the EvoScan XML.
I know your problem is different due to using 2 different laptops, but I'd check the xml file anyway.
Old May 14, 2013 | 09:12 AM
  #38
211Ratsbud's Avatar
What exactly are you sayin to do? I've closed and reopened many times. Are you thinking my XML might be formatted incorrect somewhere ?
I def need to back upy XML Before this happens lol
4 can't come soon enough
Old May 14, 2013 | 10:12 AM
  #39
Maybe. I'm backing up mine right now
Seriously though, I suppose you can rule out the ecu since you tried it on a spare. Also, you can rule out the laptops. I'm thinking you maybe correct that it is the cable or from the OBDII plug to the ECU.
Look at your XML for Evoscan and see if you find anything weird. You can send it to me too at puredriveperformance@gmail.com
Old May 14, 2013 | 01:17 PM
  #40
211Ratsbud's Avatar
http://i696.photobucket.com/albums/v...ps91c955b5.jpg
Best I can do for a screen shot for now til I get my other laptop
Old May 14, 2013 | 05:50 PM
  #41
211Ratsbud's Avatar
1) evoscan is reading data properly to use inside of itself for the map tracer.
2) my innova scan tool displays data properly.
Old May 14, 2013 | 06:16 PM
  #42
merlin.oz's Avatar
I see this occasionally, its not an ECU problem, seems to be an EvoScan thing.
Turn off EvoScan when it happens, then start it again usually fixes it for me, on two laptops.
Old May 14, 2013 | 07:05 PM
  #43
211Ratsbud's Avatar
What do you mean turn off? Stop logging? Close and re open?
Close and reopen has been done , as well as multiple logs in a session. With careful entry order and selection I'm still tuning its just a pita when I look for data in the csv
Old May 14, 2013 | 08:43 PM
  #44
merlin.oz's Avatar
Close and re-open I mean.
This typically happens if I stop looging a parameter that was enabled.
Old Jun 19, 2013 | 04:23 AM
  #45
211Ratsbud's Avatar
Found the problem
"Merge delimiters" was selected on my open office screen. But now my vd in both evoscan and vd itself show just straight lines for dyno pulls FMFL I'm saving for a real ecu ASAP
mrfred
Sep 14, 2022 07:08 PM
mrfred
Dec 7, 2015 01:49 PM
krusty
Feb 27, 2011 12:44 PM
mrfred
Dec 2, 2009 02:00 PM
Import Junky
Jan 2, 2009 09:28 PM
