High octane ignition Map and warm start?
Old Mar 29, 2013 | 07:54 PM
EvoIXPilot's Avatar
Tinkered with my ignition map by reducing timing across the board to fit 91 Octane. Flash ecu and test drove, the knocks went away. Parked the car for 20 mins to run errends and car won't start, try cranking 4 times. Finally, reflash old map and started right away. I didn't mess with any other settings. Yes, I do have FIC 1050 which I thought were loosely scaled. Did I screw up something on the map to make hard for warm start? I thought reducing timing would cause car to lean out?
Old Mar 29, 2013 | 09:16 PM
foxbat's Avatar
Post an image of your timing table
Does the old have the stock injector scaling or the larger FIC scaling/latency?
Old Mar 30, 2013 | 05:58 AM
EvoIXPilot's Avatar
I'll post it when I get home. Both maps have the same scaling (FIC). Also, I never disconnected the battery to reset the fuel trimming.
turbotaloon95
Apr 11, 2016 06:58 AM
Jim in Tucson
Nov 21, 2010 09:29 AM
Seijuro
Mar 18, 2010 03:09 PM
lan_evo_mr9
E85 / Ethanol
12
Oct 3, 2008 09:02 AM
96_LXR
Jun 6, 2006 10:02 PM
