What units do you Log oil pressure & temp
Old Mar 30, 2013 | 11:24 PM
fireroasted's Avatar
I am considering getting some oil pressure and temp logging going on. Can folks comment on their setup and why they chose the devices they did, and if they are logging with evoscan?
i am troubleshooting a nasty MIVEC problem and have eliminated everything, and now I am thinking it could be a lack of oil pressure, but I need to log it to prove that.
There are a ton of posts on the physical install of bungs on the oil filter housing, but nothing that I could find for the logging side of things.
I also have the MR oil temp gauge (that doesn't seem to work anymore that's mounted on the drain plug).
Old Mar 31, 2013 | 01:54 PM
todd6027's Avatar
did you check the filter ,in the fitting where the oil feed banjo goes into the head ?
Old Mar 31, 2013 | 09:30 PM
Yup, I did. here is a pic. Thanks for the thought though. Probably should put that on my thread for troubleshooting the actual problem.
Here I am trying to see what folks bought as hardware to log oil pressure and temp that had the right kind of output to log with evoscan. (routing into the ECU on open pins, like the Wideband input mods).
Nobody?
Showing it here half on the blue papertowel and half not so you can identify in the pic you can see through it, and therefore its clean.
honda-guy
28
Jan 30, 2021 08:48 PM
boomn29
Jul 8, 2019 05:09 PM
Cbr1000love
Jan 30, 2016 11:57 AM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
grett04
11
Mar 7, 2005 09:11 AM
