setting up mut table to start logging
i understand the concept of going into my rom id xml file and getting the address. i also understand how to install it in the correct id mut location.
the only part i do not quite get is where am i getting these addresses. say i want to log knock and make sure i have the correct address in the mut table. i go into my rom id file and look for something that says knock and take that adress? i know my meta has ALOT of tables that have to do with knock. how do i make sure i am picking the correct address.
i just want to make sure all my locations are correct before i go out and start logging. the things i want to check before logging are
my wideband o2, rpm, boost, knock, timing, idc, air temp, and 2 byte load
i still have to set up 2 byte load, wire my wideband to the ecu and check to make sure that my omni 4bar are installed correct. but thats another project im working on right now.
thanks for any help..
