High Knock after install 280º Cams
Old Apr 7, 2013 | 10:09 AM
JSPturbo's Avatar
Hello !!. I have a problem. after install a BC280 camshafts in my car, start to knocking after reaching 4000rpm 10-12 counts. With the previously JUN 264º cams Knock set to 0 generally.
Log with EvoScan:
http://www.2shared.com/file/_d337RE-...25_141233.html
Change the Valve Springs by a BC kit and set the CamGears to 0-0. But the problem still. The Ecu Map is the same with both camshafts.
Try lower the timing but nothing!!
Where can be the problem? Coils, Phantom Knock, Maybe the Cams¿?
Old Apr 9, 2013 | 07:30 PM
WRC-LVR's Avatar
Log with EvoScan:
Those cams should breathe better than the previous 264 cams. So at higher rpm more air with still the same fuel means you need to re-tune it for the cams.
Get the car re-tuned or log it with a wideband and fix the fuel maps yourself
wowzers
19
Dec 22, 2014 05:21 PM
JSPturbo
Jul 15, 2014 03:15 AM
clanzkiller
24
Jun 15, 2014 03:33 AM
domyz
Oct 19, 2013 01:23 AM
HPF Kyle
32
Oct 16, 2006 04:34 PM
