Help!ECU can not be linked with OPENPROT2.0 EVO9 not read the ROM.
Old Apr 12, 2013 | 05:16 AM
wenjie1812's Avatar
Need to link a line? Connected in what position? If a picture is the best. Thank you!
Here, I use the ECUFLASH Link ECU read LOG
[22:03:05.421] EcuFlash Version 1.44.3721
[22:03:05.421] OS Version Windows XP
[22:03:05.421] Qt Version 4.8.0
[22:03:05.437] 63 memory models read.
[22:03:05.437] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[22:03:05.875] Error parsing xml of file C:/Program Files/OpenECU/EcuFlash/rommetadata/12345.xml: Parse error at line 1, column 1:
error occurred while parsing element
[22:03:05.875] ROM metadata models 12345.xml is invalid.
[22:03:05.875] 646 ROM metadata models scanned.
[22:03:05.875] checksum module "subarudbw" loaded.
[22:03:05.875] checksum module "mitsucan" loaded.
[22:03:05.875] checksum module "mitsuh8" loaded.
[22:03:05.875] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[22:03:05.875] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[22:03:05.890] flashing tool "wrx02" loaded.
[22:03:05.890] flashing tool "wrx04" loaded.
[22:03:05.890] flashing tool "sti04" loaded.
[22:03:05.890] flashing tool "sti05" loaded.
[22:03:05.890] flashing tool "mitsukernel" loaded.
[22:03:05.890] flashing tool "mitsukernelocp" loaded.
[22:03:05.890] flashing tool "mitsubootloader" loaded.
[22:03:05.890] flashing tool "shbootmode" loaded.
[22:03:05.890] flashing tool "shaudmode" loaded.
[22:03:05.890] flashing tool "subarucan" loaded.
[22:03:05.906] flashing tool "subarucand" loaded.
[22:03:05.906] flashing tool "mitsucan" loaded.
[22:03:05.906] error loading FTD2XX.DLL
[22:07:47.828] using metadata XML ID read_mitsum32186f8can from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[22:07:47.859] J2534 API Version: 04.04
[22:07:47.859] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[22:07:47.859] Device Firmware Version: 1.12.3688
[22:07:47.859] Device Serial Number: TApFbnC$
[22:07:49.750] -- loading kernel --
[22:07:49.750] -- connecting to kernel --
[22:07:49.750] kernel get version
[22:07:49.796] J2534 error [ERR_TIMEOUT].
[22:07:49.859] J2534 error [ERR_TIMEOUT].
[22:07:50.015] J2534 error [ERR_TIMEOUT].
[22:07:50.062] J2534 error [ERR_TIMEOUT].
[22:07:50.062] interface close
[22:07:50.093] interface close
[22:08:11.718] using metadata XML ID read_evo9 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo9.xml
[22:08:11.750] J2534 API Version: 04.04
[22:08:11.750] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[22:08:11.750] Device Firmware Version: 1.12.3688
[22:08:11.750] Device Serial Number: TApFbnC$
[22:08:13.687] sending init sequence 1 (0001)
[22:08:16.890] sending init sequence 1 (0003)
[22:08:20.093] sending init sequence 1 (FFFF)
[22:08:22.796] no response to any known code
[22:08:22.796] interface close
[22:08:33.781] using metadata XML ID read_mitsum32186f8can from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[22:08:33.812] J2534 API Version: 04.04
[22:08:33.812] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[22:08:33.812] Device Firmware Version: 1.12.3688
[22:08:33.812] Device Serial Number: TApFbnC$
[22:08:35.218] -- loading kernel --
[22:08:35.218] -- connecting to kernel --
[22:08:35.218] kernel get version
[22:08:35.281] J2534 error [ERR_TIMEOUT].
[22:08:35.328] J2534 error [ERR_TIMEOUT].
[22:08:35.484] J2534 error [ERR_TIMEOUT].
[22:08:35.531] J2534 error [ERR_TIMEOUT].
[22:08:35.531] interface close
[22:08:35.562] interface close
[22:10:08.921] using metadata XML ID read_mitsum32186f8can from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[22:10:08.953] J2534 API Version: 04.04
[22:10:08.953] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[22:10:08.953] Device Firmware Version: 1.12.3688
[22:10:08.953] Device Serial Number: TApFbnC$
[22:10:10.437] -- loading kernel --
[22:10:10.437] -- connecting to kernel --
[22:10:10.437] kernel get version
[22:10:10.515] J2534 error [ERR_TIMEOUT].
[22:10:10.562] J2534 error [ERR_TIMEOUT].
[22:10:10.734] J2534 error [ERR_TIMEOUT].
[22:10:10.796] J2534 error [ERR_TIMEOUT].
[22:10:10.796] interface close
[22:10:10.843] interface close
city
Jun 2, 2017 08:34 PM
Burnhad91
Nov 10, 2015 02:43 PM
lonestarevo83
Jul 15, 2011 07:20 PM
Cali 18
Jun 24, 2011 08:55 AM
Carloverx
Dec 13, 2010 09:02 AM
