2005 evo 8 does it have a map sensor
Old Apr 15, 2013 | 01:47 AM
Jesussaves1's Avatar
2005 evo 8 does it have a map sensor? car is in the shop so i cant check. if not what will i need to get one as i think its needed for tuning via ecuflash for psi based tunes? please help clear this up.
Old Apr 15, 2013 | 06:03 AM
EvoIXPilot's Avatar
You should have one, if not it will give you a CEL and run like crap. For ECUFlash, its recommended to swap/get a aftermarket one. I have the Evo X MAP sensor (equivilent to JDM?) and its direct swap with the Evo 8. The only thing you'll have to do is change some settings in ECUflash and flash your car so you can read boost.
Old Apr 15, 2013 | 10:29 AM
Sweet thanks
Old Apr 15, 2013 | 04:35 PM
AKW89's Avatar
I would go ahead and buy you an Omni 4 Bar map. It isn't outrageous and you know you've got the best in that case. But, yes by default you have a MAP sensor. It is on top of the intake manifold. The one that comes in the car is pointless to anything but the ECU. To log get the Omni 4 bar. =P
Dwilson36
May 5, 2016 11:05 AM
BOOSTDBSTRD
Apr 7, 2014 02:39 PM
Jesussaves1
Apr 20, 2013 08:12 PM
millsyy17
11
Aug 5, 2011 07:55 PM
topnotch_EVO
May 21, 2010 07:21 AM
