newbie ecuflash confusion
Old Apr 27, 2013 | 08:22 AM
SS1000RR's Avatar
hi guys im new to this forum but ive been a whole lot of reading and I cant seem to find the answer to what im looking for. Car is 06 evo ix using 1.3 tactrix with newest ecuflash software.
Problem im having is that when i read from ecu i get message saying "unknown rom image" now i've been looking into the tephra v7 but my problem is that I dont understand how to get it to work. How and what do i copy where exactly is my question.
ill try and attach the file i downloaded from the ecu. all help is appreciated
thx in advance.
File Type: bin
Old Apr 27, 2013 | 08:47 AM
burgers22's Avatar
ROM ID is 96940011, soory I don't have an XML for that, but someone will be along with the correct deffinition file. You will need to put that file into the C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo folder. That is for WIndows 7.
Old Apr 27, 2013 | 09:20 AM
SS1000RR's Avatar
Ok thank u, hopefully somebody has a XML for me. Car is running super rich and I wanna fix it asap
Old Apr 27, 2013 | 09:49 AM
burgers22's Avatar
If it is running rich and you haven't made any major changes - then you need to look at some fault, a fault O2 sensor for example. Though the stock map is rich on boost, it should run 14.7 AFR on cruise and 12 is during spool - fix the fault first.
Old Apr 27, 2013 | 10:13 AM
SS1000RR's Avatar
I just bought the car, it was tuned on stock fuel system and after it was tuned the previous owner put a 255 walbro in it and it messed it all up. So now Im just trying to get it somewhat running before I take it in to stm.
Old Apr 28, 2013 | 06:24 AM
SS1000RR's Avatar
bump
anybody have a xml for this rom? I also have to disable rear 02 since i noticed one wire is broken on it
Old Apr 28, 2013 | 06:38 AM
WRC-LVR's Avatar
Hi,
96940011 is for an 2005 USDM Evo 8. It is the last of the 512K Evo ECU's . The latest version of ECuflash has that definition and xml.
The 06 and up Evo 9 use a different ECU designed with the Mivec cam system that came on the 9's. Those are 1024K version roms. Your Rom may have been locked or had the ROM version changed to stop people from reading or messing with the tune.
Here is a link to the EVOECu wiki page. http://evoecu.logic.net/wiki/Downloads
The correct ecu Rom version is 88590013 or 014 or 015 for your evo, if it is indeed an 2006 Evo 9 . You need to confirm the year and model of the car as there is no reason to have an non-mivec evo 8 ecu Rom on a Evo 9 mivec car.
You can use the Tephra mod 7 that replaces the 8859xxxx for the Evo 9.
However before doing any tuning you need to fix the issues like the rear o2 sensor. Since you are a complete newbie as you say, then I would suggest contacting one of the tuners online here that do remote tunes to tune the car. That way you will be safer and end up with a decent tune. They will be able to help unlocking and /or reflashing the correct rom as well as the correct Tephra v7 version.
Hope that helps !
Old Apr 28, 2013 | 11:34 AM
SS1000RR's Avatar
Ok Thanks for clearing that up for me. What's a good remote tuner I should look into?
Old Apr 28, 2013 | 12:29 PM
PureDrivePerformance's Avatar
I can tune your car. I'm finishing up a couple of customers today, but have time tomorrow. Check out my website and let me know.
Old May 1, 2013 | 06:55 PM
SS1000RR's Avatar
"You can use the Tephra mod 7 that replaces the 8859xxxx for the Evo 9."
how exactly do i replace my current evo 8 rom with the correct evo 9 rom?
Copy the proper rom to the evo folder and then what? write to ecu or somethin else?
Thanks guys
I just want the correct rom in this car and then i'll have it tuned from scratch.
Old May 2, 2013 | 02:36 PM
burgers22's Avatar
If you are going to tune yourself, start with tweaking your existing ROM, the tephra ROMs can be a bit overwhelming to start with. I'll have a look round for and xml for you, look at you tube for some great guides
Old May 2, 2013 | 08:28 PM
SS1000RR's Avatar
I can't tweak the existing rom because I can't access it, ecuflash can't read it, and it's a evo 8 rom I guess. So I have No idea how to flash a new rom to the ecu when it doesn't let me.
Old May 4, 2013 | 08:25 AM
SS1000RR is all set. I flashed the IX Tephra rom on there. Car fires right up and running stoich.
He's going to boost leak test it and fix an exhaust leak. Then I'll be tuning it within the next few days.
Old May 4, 2013 | 01:17 PM
SS1000RR's Avatar
^^^^ you're the man!!
Old May 5, 2013 | 01:34 PM
burgers22's Avatar
Glad you got a good ROM on there - I did some investigation and your original ROM is actually a (badly) tuned 88590015, so your likely better off with a tuned new ROM.
