EGR flow changes with speed density
Old May 4, 2013 | 11:34 AM
Dynotech Tuning's Avatar
MrFred, how do you determine what are the new MAP sensor parameters in the ROM tables for the JDM, OMNI,etc? I am having a hard time finding a connection between the USDM 1 bar paramters, the JDM MAP sensor and others.
My assumption would assume that the raw decimal values are actually KPA values. This would make the "EGR pressure diff" appear to be a 3kpa value. I could see the ECU looking for a 3kpa variance during the EGR test plausible enough to support my theory.
I noticed the OMNI 4bar uses the same updated values too which made me think that these values were just set high todisable certain unwanted things from occuring?
-Jamie
Old May 4, 2013 | 12:04 PM
mrfred's Avatar
-Jamie
I never bothered with trying to translate the raw values to actual pressure values. The FSM says 3 KPa (0.4 psi), so you are correct in your estimation of the values. Its pretty much within the noise of what a 4 bar can detect (1.5 KPa is the digitized step size with a 4-bar), so there's little value in actually putting realistic values in the table.
Old May 4, 2013 | 04:21 PM
So I scaled the MAP sensor tables using KPA instead of Volts and here is the comparison between the USDM sensor and the JDM Map sensor:
Note: (my findings point towards the stock 1 Bar KPA scaling is the same as the baro sensor which is x*0.5)
Now I don't know exactly what each parameter is truly for, orwhen they are called upon but I'm trying to understand it more.
-Jamie
Attached Thumbnails EGR flow changes with speed density-map-sensor-comparison.png
fostytou
359
Oct 23, 2025 09:54 AM
Appauldd
Sep 21, 2015 08:39 AM
domyz
Sep 3, 2014 08:14 PM
r4p.t0x
Jun 29, 2014 10:17 AM
killerpenguin21
Aug 14, 2013 04:28 AM
