How to wire zeitronix wideband into ecu?
Old May 2, 2013 | 06:19 PM
xXANCHORMONXx's Avatar
Are there any diys on here that have a step my step diy on how to do this?
Thanks in advance
Old May 3, 2013 | 10:02 AM
EvocentriK's Avatar
Here mate https://www.evolutionm.net/forums/10158944-post440.html
Old May 3, 2013 | 02:38 PM
Wow awesome thanks!
Old May 3, 2013 | 08:08 PM
Dynotech Tuning's Avatar
There is a more accurate way of logging the zeitronix through the ECU.
There is always a voltage variance between the analog output and what the ECU input see's.
Once you connect it to the ECU, turn on the wideband but unplug the sensor itself (with the engine OFF). The analog output will output 2.55 volts (14.7:1 AFR). In Evoscan, if you set the formula as just 'x' 2.55 volts would read 130.
99% of the time this wont be what it reads.
replace the letter 'P' with whatever you logged when you had the formula set to just 'x'. reconnect the wideband sensor and now your readings will perfectly match.
(10/255)*(x*(130/P))+9.6
-Jamie
Old May 3, 2013 | 11:53 PM
Thanks Jamie
I try it this weekend.
Old May 4, 2013 | 11:55 AM
Boosted Tuning's Avatar
When I wired my Zeitronix to the ECU, I logged the AFR from the ECU while logging the AFR from the zeitronix box using reg serial cable and made sure they overlaid each other, to make sure my formula was 100% accurate.
Old May 4, 2013 | 12:52 PM
I was thinking about that. Once I get it wired up it may be a good idea.
Old May 12, 2013 | 08:29 PM
Raptord's Avatar
-Jamie
Jamie, I followed your instructions but my analog output only matches the serial output at 14.7. The analog output reads leaner than the serial output when richer than stoich. I'm going to check what reading I get in the ZDL software tomorrow to confirm which one is correct.
Old May 12, 2013 | 08:38 PM
Ill try to remember to get the formula Im using with mine off my laptop tomorrow and Ill post it up.
Old May 13, 2013 | 04:45 AM
What was the value you got for 'P' in the formula?
Old May 13, 2013 | 06:02 AM
Raptord's Avatar
129.
I tested analog output in evoscan vs serial output in ZDL vs my zeitronix LCD this morning and confirmed that the analog output differs from both the serial output and LCD, and serial output matches the LCD reading.
FiReBReTHa
Lancer How Tos / Installations
Jul 9, 2020 06:03 PM
TWM Performance
Evo X How Tos / Installations
Sep 12, 2013 09:07 PM
boost310
Apr 24, 2013 07:52 AM
GsrJake
Nov 30, 2012 07:38 PM
Buguy
May 15, 2012 02:45 PM
