Code P0110 IAT Circuit Malfunction
Old May 4, 2013 | 01:36 PM
Big Bald's Avatar
Question Code P0110 IAT Circuit Malfunction
I recently purchased this Evo and this seems to be the last code I need to get rid of to pass emissions. The car is running a speed density setup using the Fuel Temp Sensor I believe. Is there any way to get rid of this code short of buying an IAT sensor and hooking it up? I tried searching and never really found an answer to this. Thanks in advance for any and all help.
Old May 4, 2013 | 03:08 PM
Dynotech Tuning's Avatar
You should probably confirm its setup properly in the settings first. What setting is the IAT sensor set to? 0x03 or 0x0E?
-Jamie
Old May 4, 2013 | 03:57 PM
Big Bald's Avatar
So it looks like it reads -40 flat all the time. I am new to this so bare with me. Where is that setting located at in ECUFlash?
Old May 4, 2013 | 04:17 PM
211Ratsbud's Avatar
In the sd settings
Old May 4, 2013 | 04:23 PM
Seems like its set for the Front MAF plug inout and not the fuel temp sensor. Is this in an Evo? I see that you have a DSM in your profile.
-Jamie
Old May 4, 2013 | 05:59 PM
Big Bald's Avatar
SD Option: Hex 0E. I assume that is what you are asking for? or is there another place I should look?
03 GSR is what this is for and what I have.
Old May 4, 2013 | 06:06 PM
211Ratsbud's Avatar
Would a lacking sensor even return a value? My gm iat that went bad stuck at one value but never threw a code
0E means its set for the fuel temp sensor but yours doesn't seem to be functioning correctly.
-Jamie
Old May 4, 2013 | 06:22 PM
Big Bald's Avatar
So this was using one of those obdii scanners. That is where i am getting the code from. I will check Air Temp in Evo Scan in a minute to compare.
Old May 4, 2013 | 06:32 PM
The formula for Air Temp Scaled is 1.8*x-40 so if the signal is zero it will read -40 like he was seeing. Fuel temp sensor is located in the middle of the fuel tank. I haven't seen one to bad before but it's always possible.
-Jamie
Old May 4, 2013 | 07:59 PM
Big Bald's Avatar
and it runs straight to the ECU?
Old May 4, 2013 | 10:32 PM
Yeah. I don't know how many connectors might be between the sensor and the ECU though. It cod always be a bad connection somewhere.
-Jamie
Old May 5, 2013 | 04:33 AM
Big Bald's Avatar
I spoke to the previous owner and he say that is fine it's a SD thing. The car starts and drives fine they way it is currently configured.It would have to be getting a good reading from somewhere in order for that to be true i would think.
When loggin via EvoScan it returns a -85 constantly.
Edit: Based on your other post looks like i am looking at the wrong value on EvoScan. I will log that today to see if it is working.
Will any of this cause me to get the CEL Code of P0110? I can't figure out how to disable the code. That is my only concern really....
Old May 5, 2013 | 04:40 PM
Big Bald's Avatar
So i have verified that the temp is working correctly. I was loggin air temp in EvoScan when i should have been looking at Mar Air Temp Scaled. That is reporting a actual value.
My obdii scanner think i have a bad IAT circuit. How do i fix that? Does that code affect my ability to pass emissions?
Old May 5, 2013 | 05:16 PM
211Ratsbud's Avatar
I think that depends on the state. In ny code =fail
