cannot open ROM file
Old Jul 21, 2013 | 02:35 PM
nismo3183's Avatar
Forgive my ignorance on ecuflash in general as I am very new to it and trying to learn as much as possible.
I would like to begin tuning but have been trying to get a few things setup in the metadata before modifying any parameters. After reading through Merlin's guide and watching Recompile's videos, I wanted to I start by adding MUT table access in my Metadata. I downloaded notepad portable ++ and have been able to access the XML file to add tables. I found this thread that has the correct xml format for my ROM https://www.evolutionm.net/forums/ec...6420008-a.html. As instructed by mrfred I just cut and paste coding in between the appropriate coding.
At this point I saved the file as an xml file and located it in the evo folder that all other default ROMS are stored in when ecuflash was downloaded. I am confused on what I have to do next. Do I have to save the same file in a hex or bin format somewhere else?? If I do this I get an error that says improper ROM image. Any help would be greatly appreciated. It isn't necessarily the MUT tables that I am having issues with. I am having issues incorporating new data into the metadata tables in general.
thanks
Old Jul 21, 2013 | 04:44 PM
nismo3183's Avatar
I think I figured it out. I was making it much harder then it had to be. Just copied xml and inserted into 96420008 in the evo folder under openecu. MUT tables are up.
Old Jun 17, 2023 | 01:29 AM
Dow Jhob's Avatar
evooman
Jul 26, 2011 03:36 PM
joshl'sevo8
Mar 28, 2010 03:31 PM
nitrousbhp
Dec 15, 2009 09:13 AM
lan_evo_mr9
Nov 27, 2008 07:37 PM
ohthree
Nov 7, 2007 10:01 AM
