Bad sensor or what? Can't figure this out
Old Nov 29, 2013, 10:10 AM
MacMan's Avatar
My Evo has developed a weird symptom. I'm tuned open loop 24/7, so my afr map has around 17 afr for idle. When I start the car, I log it and the ecu sees the proper 17afr in the map, which puts me at 15.5 on my gauge ( perfect )
Here's the problem... once the car warms up, it's as if the ECU stops seeing the proper number in my afr map.... same 17 in the map, but now it says the ecu sees it as 13.8afr instead, which is making me go really rich (12 flats)
It's none of the usual suspects.... boost/exhaust leaks, vacuum/ground issues. I'm 100% good, it's def something else. So guru's, what could cause the ECU to stop seeing the proper number in my afr map and see it as 3-4 full points lower once warm, but is perfectly fine when warming up. It also kinda just started to happen out of the blue. WHen braking, i would notice the idle dip down 3-500rpm lower than it's suppose to, afr's fall down rich... would never die and would eventually get it'self right. It doesn't seem to affect the car while driving... my cruise afr's are on point.
I checked my IACV, pulled it out and turned the car to ON. It clicks and moves, albeit not much movement. I cleaned it with carb cleaner and reinstalled... still happens. TPS sensor reads right at no throttle and 100% at WOT. I'm on speed density, my OMNI 4 bar is less than 3 months old, would like to think it's still ok. ANything I could log to try to figure out an answer or SOMETHING!?!??~?
Old Nov 29, 2013, 06:27 PM
ReaperX's Avatar
How long ago were you tuned and what is the temperature difference from when you were tuned to current?
Old Nov 30, 2013, 03:48 PM
MacMan's Avatar
I'm CONSTANTLY tuning this thing.
Old Nov 30, 2013, 05:10 PM
ExViTermini's Avatar
What do the ECT and IAT say?
Old Dec 1, 2013, 05:11 AM
MacMan's Avatar
Am tuned using the fuel temp sensor so no IAT, and pardon my ignorance but I don't know what ECT references.
Old Dec 1, 2013, 10:30 AM
todd6027's Avatar
engine coolant temp
Old Dec 3, 2013, 11:01 AM
MacMan's Avatar
Originally Posted by todd6027
engine coolant temp
In the log I just looked at... 190-210
Old Dec 5, 2013, 01:29 PM
MacMan's Avatar
was a bad map sensor.
awdordie
Jun 15, 2017 10:00 AM
Raceghost
May 21, 2016 12:37 PM
nerdbotSKRA
41
Mar 29, 2012 11:16 PM
Quick Reply: Bad sensor or what? Can't figure this out
