Using a 1.3R to flash
Old Dec 25, 2013 | 12:21 AM
blackandredgts's Avatar
Hey guys I recently picked up a 1.3r cable secondhand for cheap. And I just wanted to know how you guys use it to flash? Cause I've read that there's issues doing so with the 1.3R and that the 1.3U is the one to buy. Well is too late now and I just need some help in getting around this! Thanks!
Old Dec 25, 2013 | 04:30 AM
Broke4speed's Avatar
It flashes fine with Evoscan. It won't work with ecuflash, that's all.
Old Dec 27, 2013 | 04:36 PM
jrainwater's Avatar
Evoscan takes FOREVER to flash and ecuflash takes like 20 seconds to flash, if that. I have a 1.3r and all I did was use an older version of ecuflash to flash. I want to say its version 1.29, then you can make changes to your Rom with version 1.44. I eventually got sick of going back and forth and bought an OP2.0 also. But ya, if you want to use the 1.3r with ecuflash just download the older version 1.29 to flash and 1.44 to make Rom changes.
Old Dec 29, 2013 | 07:29 AM
So you can flash with ecuflash? Just the older 1.29 one correct? And do you guys know anywhere I could possible get evoscan and ecuflash for free?
Old Dec 29, 2013 | 07:37 AM
WRC-LVR's Avatar
EcuFlash is free. EvoScan is USD$25 and well worth it. Pay the money !!
Old Dec 29, 2013 | 10:47 AM
Yeah, $25 is pennies for the value it has for your car .
I can confirm that the 1.3R cable works with older Ecuflash, as I have an R cable. I think the last version without the cable ID stuff added to it was 1.34.
Old Dec 30, 2013 | 06:22 AM
jrainwater's Avatar
Anything newer then 1.29 will not work with a R cable. Been there done that.
Old Dec 30, 2013 | 08:25 AM
Really? I was using 1.34...
I'm working with Evo 8/3G eclipse/02-04 Lancer AT/01-04 Sonata AT ecus.
Old Dec 30, 2013 | 08:58 AM
I also have another question what is the difference between Evoscan and ecuflash? Also the only reason I got the 1.3r is because I got it extremely cheap locally. Thanks any help is appreciated!
Old Dec 30, 2013 | 09:02 AM
Evoscan is a datalogging program that has a freebie read/write function built in (for evo 8/9 only). ECUFlash is a read/write/ROM editing program.
To use the R, you do all your work in ECUFlash, save it as a hex file, and then flash it to the ecu with Evoscan.
Old Dec 30, 2013 | 10:49 AM
jrainwater's Avatar
Really, that's interesting. Yeah I'm not sure why you were able to use a newer version but my R cable wouldn't work with anything newer then 1.29. I did buy the R cable recently (6 months ago) so maybe if yours is a little older they could have changed the firmware in the end of the plug or something.
Old Jan 24, 2014 | 09:36 PM
Another question is where can I get the older ecuflash?
Old Jan 25, 2014 | 07:29 AM
jrainwater's Avatar
http://www.evoscan.com/free-ecu-rom-downloads
This has all the old versions of ecuflash(scroll all the way to the bottom of the page). I've only been able to get 1.29a to flash with a R cable but broke4speed says 1.34 worked for him. For me though again nothing later then 1.29a worked.....
Old Jan 27, 2014 | 07:31 PM
Thank you soo much!
Old Jan 28, 2014 | 03:51 AM
I am willing to accept I was wrong, haha. I haven't had the time to check again, so stick with 1.29a. It's a definite solution.
