TephraXMOD V2
Old Feb 15, 2014 | 06:41 PM
tephra's Avatar
yep same pin
when leaving methsafe it will revert to the normal map...
if I made it any more complicated I think it would be dangerous
Old Feb 15, 2014 | 06:54 PM
chriswolf81's Avatar
Lol. You Sir are the man. Multiple alt maps can revert back to the normal map.
What do other platforms do without a Tephra
Old Feb 15, 2014 | 07:24 PM
tephra's Avatar
its only the methsafe map that will revert to normal..
Old Feb 15, 2014 | 07:58 PM
MR_mike's Avatar
Can't wait to get this but need to get the car running again way excited
Old Feb 15, 2014 | 08:04 PM
01sporty's Avatar
Where do send money? I have a few x's that want this
Old Feb 15, 2014 | 08:16 PM
Ok got you. So when in meth fail safe mode you can only use the alt map and normal map to revert back to. So if I wanted to use other maps for track day, what would I do?
If I switch to the cruise control alt map mode, I will trip the check engine light, due to the high jacked gas tank temp signal.
Just trying to wrap my head around what my options are, with very little tuning knowledge
Old Feb 15, 2014 | 08:37 PM
bellacotim's Avatar
I'm in if 59590004 13-14 USB become available?
Edit:
I tried to PM you, but forgot your inbox is full. Please check your pp donate globalshare net email.
Old Feb 15, 2014 | 09:37 PM
tephra's Avatar
yeh sorry PM's are full as... you can email me on <myforumname> at gmail.com...
whats 59590004? 2013/2014 USDM SST?
Chris - With the methsafe map, the meth controller can put it onto the methsafe map, and then take it back to normal map.. the gas temp signal should be always be overwritten regardless..
do you have a bench cable? if you like I can advance you a copy (send me the ROMID) and you can test it all out for yourself..
lastly - I am just finishing of 53050009 - Should be tested in the next few days...
Old Feb 15, 2014 | 11:22 PM
nonschlont's Avatar
Nice!!! Looking forward to testing..
Old Feb 16, 2014 | 05:15 PM
I don't have a cable and don't even know my Rom id.
2008 gsr us with tephra mod v1
I would love to learn how to switch maps with the lap top.
Maybe there is a YouTube for dummies to learn the ecu flash basics.
Old Feb 16, 2014 | 11:55 PM
prowakeskater's Avatar
woohoo
Old Feb 17, 2014 | 05:07 AM
itzwolf's Avatar
Since no one has asked yet...
Once V2Mods is flashed the initial time does further flashing require the bench flashing method?
What kind of realistic time frame are we looking at for the updated ECUFlash software?
Can we have a list of live tunable maps? Is the fuel calibration map one of them by chance?
Edit:
Also I have a 2011 running the 2010 v1 ROM and wish to stick with the 2010 ROM. Will the 2010 v2 still work this way due to the amount of changes you've made? I'd presume yes but figured others would like to know so asking this publicly also.
Old Feb 17, 2014 | 07:17 AM
zigzagzok's Avatar
tephra
your inbox is full
sent you some...
Old Feb 17, 2014 | 07:46 AM
Fede's Avatar
WOW!!!
Thanks a lot!
Old Feb 17, 2014 | 12:19 PM
mmv's Avatar
mmv
Originally Posted by gsxrmel
also Would be great if you can port the V2 features for EDM 53050009 ROM.
thanks for all the work
Hi Tephra!
I also would like to test or buy the EDM 53050009 SST ROM.
