TephraXMOD V2
Old Nov 1, 2015 | 09:07 PM
  #511
kaganader2's Avatar
Registered User
He emails you a xml def file along with the rom. Use that
Old Nov 2, 2015 | 04:24 PM
  #512
onyx1121's Avatar
I think there is just some confusion because I worked through Chet since is doing my tune (he worked with Tephra to convert my ROM, etc.). All resolved now though since Chet sent along the XML.
One more question for those that flashed this via ECUFlash - I assume nothing looks/acts different in ECUFlash when the patch is applied? I just flash as normal? I wasn't sure if there was some way to confirm TephraXMod had been successfully installed. When I logged in Evoscan it seemed faster, about 190 samples/sec.
Old Nov 2, 2015 | 05:31 PM
  #513
richardjh's Avatar
I believe tephra's V2 work includes significantly optimised "mode23" data transfer.
So, yes, you would see EvoScan om-nomming a lot more variables per second.
Rich
Old Nov 18, 2015 | 10:20 PM
  #514
zigzagzok's Avatar
no sound from tephra for a while wonder what is the status of V2 for SSTs?
Old Nov 19, 2015 | 10:46 AM
  #515
polik71's Avatar
All the work is moved to the V3 (that is V2+Flexfuel) , but also there I don't know news since weeks/months for our SST. It was nearly "ready to go" and some are betatesting too but I'm starting to loose the beliefs at this time.
I donated for the V2 + EvoX-Tool back in Feb-2014 but this SST issue seems impossible to overcome
Old Nov 20, 2015 | 12:56 AM
  #516
richardjh's Avatar
As far as I understand from tephra...
In V2, the "Current Map" indicator used the tacho to show Map 1-9, eg. 1krpm-9krpm.
Unfortunately, on SST vehicles, the rpm info sent to the tacho was also processed by the SST TCU! And it did not like seeing impossible/mismatching rpm values compared to other things it was able to observe.
So a fundamental incompatibility that couldn't be worked around on SST.
Rich
Old Nov 21, 2015 | 04:32 AM
  #517
Fede's Avatar
And what about using a flashing light as for knock cell? 1 flash first map, 2 flashes second and so on or other simple tricks?
I don't believe I'll need all V2 maps but 4 would be great!
Our SST cars need a little love ;-)
Thanks
Rich
Old Nov 21, 2015 | 10:50 AM
  #518
RazorLab's Avatar
Guys with SST should really look at tephras site:
http://www.tephra.it/v3/
"MR (SST) support - Unfortunatley TephraXMOD V2 wasn't able to support SST's (the Tacho replacement also feeds the TCU, and SST's didn't like being told they were at 9000rpm, when they TCU knows the input shaft was running at 2000rpm (or whatever). V3 keeps the tacho altmap selector method for GSR's (5MT), and adds a Intercoooler Spray light flasher to SST's."
Old Nov 24, 2015 | 11:57 PM
  #519
Beeble's Avatar
^yup, for SST it will use the knock light flashing to tell you what map you are on.
As a tester for the V2 on the SST, trust me if you ever wanted to see the gearbox develop multiple personalities and then need an exorcism, this was the way to do it. And that was just sitting at idle in my garage!! changing maps while actually moving caused the earth's rotation to change several times per second.
Old Dec 1, 2015 | 01:34 AM
  #520
tephra's Avatar
V3 = this week... I promise
actually i shouldn't say that .. haha...
Old Dec 1, 2015 | 04:01 AM
  #521
Dennis1086's Avatar
Tephra, I have emailed you about upgrading from V2 to V3. Can you let me know how much for the upgrade? Cheers
Old Dec 1, 2015 | 12:15 PM
  #522
GP148's Avatar
Is anyone able to help me define the minimum IPW patch for 56920008? Want to have this working before I upgrade to V3. I have 1600cc injectors so this is a must
Old Dec 4, 2015 | 11:28 AM
  #523
ddlopresti's Avatar
is v3 available for a 2013 GSR?
Old Dec 5, 2015 | 05:38 PM
  #524
polik71's Avatar
As far as I know the GSR is covered by V3 (59580004 in the first post of this 3d)
Old Dec 5, 2015 | 05:54 PM
  #525
polik71's Avatar
I also wrote to him about the upgrade $$$ from V2 to V3 (at last ready for my MR/SST problem) , but no response...
I'm quite sure he is busy for the last details on the FlexFuel part(CANBus compatibility)
He promised the V3 out for this week , it depends if down under is working the other way round , like the week is ending on...wednesday?
Sorry Tephra , just kidding , but from last year I'm really drooling for this upgrade
We all owe you much , so take all the time you need.
