Idle Tuning
Old May 3, 2014 | 07:55 AM
LTEDDER's Avatar
Idle Tuning
I have an 05 MR, I am using ROMID=96940011
The car has FIC 1050's, along with GSC S2's
Forgive me as I am new to this,
I have adjusted the BISS correctly, and I can get the car to idle where I want it around 1000 RPMS with the A/C off. The problem that I am running into is when I switch the A/C on, the car really wants to stall, and sometimes does.
I have tried adjusting Desired Idle RPM-with AC on, with some luck, Currently I have it set to idle at 1300 with the A/C on.
I have also adjusted the Desired ISCV initial step position with AC on. In the 77 and 82 temp rows I have tried values anywhere from 50 to 150.
My ignition Timing is 9 degrees at 1000 RPMS from 10-50 Load.
I am trying to keep the lope , but I also am trying to get the car to idle reliably with the A/C on. I understand If I am unable to have the best of both worlds. I was just wondering if there was anything that I am missing.
Thanks in advance
Old May 3, 2014 | 08:30 AM
Abacus's Avatar
I can't help with the ISCV table settings but I'd say raise the timing/rpm up and get a smoother idle. Its a PITA if your car stalls out around a turn with the clutch in or in a parking lot. I've also spoken with TRE and he said that a really lopey idle is hard on the transmission. I'm not sure why but I would believe him since he has rebuilt alot of transmissions.
Old May 4, 2014 | 03:18 PM
LTEDDER's Avatar
Thanks for your response. But raising the idle stability timing control limit allowed the motor to catch itself.
Old May 4, 2014 | 06:08 PM
ReaperX's Avatar
Set the Idle Stability Timing Control table to 3 in the timing limit, and set your idle timing to 15*. You'll still lope and wont have to worry about stalling. Those are the settings I run with my car on S2's. Rock solid 1k idle.
rich3389
Sep 8, 2024 07:27 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
SW20Mike
36
Jul 7, 2018 09:00 AM
widge
May 11, 2010 07:16 AM
lan_evo_mr9
Jun 23, 2008 07:28 PM
