21/27.7 mpg - optimizing mileage
Old Jun 10, 2014 | 04:03 PM
  #31
Abacus's Avatar
[QUOTE=tsitalon1;11199736]Hey guys,
I'm making good progress from when I bought this car.
Before my mileage was 15/21, now it's 21/27.7. not bad for 400whp
I'm using open loop cruising and here are my AFR and Timing tables:
Thats impressive mileage. Do you think the engine is really tolerating all that timing at 2600-3000? Depending on knock settings/filters it might not set off the check engine light (V7) I'd imagine a lean afr and high timing would be hard to pull off with an EVO engine at low speeds. Now if you drive it carefully with very low throttle at low speeds it might be ok.
Old Jun 10, 2014 | 05:23 PM
  #32
surfersamu's Avatar
I log my car daily with standalone logging with tactrix and never get knock... and im running more timing than him...
Old Jun 10, 2014 | 09:48 PM
  #33
211Ratsbud's Avatar
16.2 couldn't hurt, but gains are so minuscule and emissions for nox I think spike right there. I had misfiring at 16.7ish (gauge ).
I'd like to increase my mileage on my vipec but I'm stuck. Lol closed loop lambda isn't tolerating light cruise loads well at all
Old Jun 21, 2014 | 05:49 AM
  #34
misterchonger's Avatar
I am running as much timing as you are also and don't see any increased knock. I was running 16.7afr but have come down to 16.2. Mivec commanded to 15* in cruise regions. Last tank avg was 28mpg mostly on hwy but had a few hard pulls in there.
Old Jun 21, 2014 | 10:50 PM
  #35
surfersamu's Avatar
wow so u probably are grtting 30mpg without boost... can u post ur afr map? also... did u change mivec intake or exhaust?
Old Jun 22, 2014 | 07:04 PM
  #36
My scangauge has read 30+ mpg while cruising on the hwy but that is an average over that small time period/trip. I have not gotten close to 30mpg on an actual tank average. My AFR map is on another PC. I'll try to remember to screenshot it next time I'm in there. I redid my entire MIVEC map. Most of the map is nothing new. Did some experimenting with the scangauge and 15* seems best on my setup for cruising fuel.
Old Jun 28, 2014 | 09:39 PM
  #37
superkizuna's Avatar
so tuning: AFR, timing, and mivec is how you guys are getting that good mpg?
Old Jun 29, 2014 | 03:16 AM
  #38
That's an important part of it. Obviously driving style plays a big part as does general vehicle maintenance. Other big factors are terrain, you won't be getting good gas mileage on this car if you have to drive up hills everyday. Lastly, aero is something a lot of people forget about when thinking mpg.
C6C6CH3vo
Mar 9, 2023 10:19 AM
mrfred
Sep 14, 2022 07:08 PM
razorlab
Sep 14, 2019 07:23 AM
SnailSpeed
Oct 22, 2012 10:00 AM
nj1266
125
Jan 12, 2010 07:37 AM
