Speed Density and Warming Up
Old May 27, 2014 | 10:26 AM
DvlInDskyz's Avatar
I am curious. I am running SD on a 2.3L E85 motor. Now, when I first start the car (not warmed up), it fires and runs great for the first 5 or so seconds then it starts to drop RPM and dies. I notice that the WB02 goes lean. When the engine is warm, it doesn't do that. It fires and idles perfect, but only when it's warm. I constantly have to try and keep the RPM around 2k by pressing the gas a bit so it won't die. So, I guess my question is what really happens on first startup that it runs so good within those first seconds? And Second, what are the best tables that should be adjusted to accommodate for the first starting temp vs. warm temp engine?
Old May 27, 2014 | 06:21 PM
hutch959's Avatar
ive posted the same question on some other threads with no answers.
I have the exact same issue.... on speed density.
Old May 28, 2014 | 11:16 AM
goosey2099's Avatar
I'd like to know the same
Old May 28, 2014 | 12:01 PM
JohnBradley's Avatar
MAF Comp vs Coolant #1 and #2, also called Post Primer Enrich #1 and #2.
Old May 28, 2014 | 04:10 PM
DvlInDskyz's Avatar
Thank you for the response JB. I'll give it a shot. thank you!
evo360bhp
May 28, 2017 01:41 PM
Benja
Jan 11, 2017 01:03 AM
Hotsauce101
Nov 18, 2015 11:35 AM
EvilTechnology
Jun 24, 2015 09:22 PM
scheides
17
Dec 16, 2010 02:07 PM
