Lets talk peak "tq"
Old Jun 6, 2014 | 05:48 AM
jeffbeagley's Avatar
Lets talk peak "tq"
What is it that you consider to be peak tq? Peak TORQUE, Map, Load?
Reason I'm asking is my car achieves these values at pretty different times. Attached is a 3rd gear graph on Virtual Dyno for reference, and the raw log.
Reason I'm asking is I'm trying to make sure my car is reaching the appropriate timing for peak "tq".
Also note I didn't go 100% throttle until 4500rpms so the spool is rather late, I don't like to build boost so low on a stock bottom end. I also changed my Map-KPA settings to better suite ~33psi since it was only hitting ~260load before.
TPSRPMTimingSpeedLoadAFRBoostIATWGDCO2VoltageIDC
38.03923656.253341.010568.413.913-2.7558601.932486.24
38.82353687.53041.010569.613.913-2.51818601.932486.29333
39.21573718.752942.253270.814.226-2.28128602.127686.34667
39.60783718.752942.25327214.226-2.04438602.127686.34667
4037502942.253274.413.9913-2.04438601.971527.2
4037502942.253274.413.9913-1.80748601.971527.2
41.17653781.252742.253275.613.6782-1.5705861001.834888.06667
42.35293812.52542.253279.213.6782-1.0967861001.834888.13333
43.13733843.752342.253280.413.013-0.8598861001.444489.02
48.23533843.752142.25329012.89560.324699861001.444489.02
55.68633906.251942.253294.812.19131.272384.21000.9564810
603906.251742.253294.811.87821.746184.21000.9369610
63.52943968.751745.981597.211.52611.98384.21000.6051211.0067
70.196140001645.9815100.811.17392.456884.21000.585611.0933
804031.251545.981510211.48692.930684.21001.171211.18
80.78434062.51545.9815103.212.42613.404484.21001.2102412.1333
81.56864093.751445.9815109.212.42613.641384.21001.366412.2267
84.313741251445.9815111.612.73913.878284.21001.366413.2
86.27454156.251445.9815110.412.73914.35284.21001.3273613.3
90.19614218.751445.981511412.62174.825884.21001.3078413.5
93.725542501345.9815115.212.62175.299684.21001.171215.4133
96.07844312.51248.467122.412.26955.773484.21001.1321615.64
96.47064312.51248.467127.212.26956.484184.21000.8393616.56
96.862743751248.467127.211.29136.957984.21000.6441617.7333
97.25494406.251248.46713211.29137.668684.21000.4684817.86
97.64714468.751248.467135.610.19578.379384.21000.097619.0667
98.431445001048.467145.210.19579.326984.21000.097620.16
98.82354562.51048.467151.210.117410.274584.21000.0585621.4133
99.60784593.751048.467152.410.117411.222184.21000.0585622.54
1004656.25948.46716210.117412.406684.2480.0585623.84
1004718.75948.467166.810.117413.82884.2480.0585626.1733
1004750852.1952175.210.117415.012584.2480.0585627.36
1004843.75552.1952184.810.117416.670884.2480.0390429.9667
1004875452.195219810.547818.802986480.292831.2
1005000252.1952214.810.58720.698186480.292833.0667
1005031.25152.1952219.611.21322.830286480.6246435.42
1005093.75152.1952237.611.252224.488586480.6246436.9467
1005187.5152.195224611.330426.146886480.6636838.7333
1005218.75152.1952249.611.330426.857586480.6636838.9667
1005343.75252.1952247.211.408727.805186480.7027241.04
1005375359.6516253.211.408728.04286480.7027242.4267
1005531.25459.6516253.211.447828.752784.2480.7417642.48
1005531.25459.651626411.486929.226584.2480.7417643.66
1005718.75659.6516259.211.486929.463484.2480.7417645.14
1005718.75659.6516261.611.486929.226584.2480.7417645.14
1005875859.6516261.611.486930.174184.2480.6051246.3733
1005937.5859.651626411.173930.41184.2480.585646.8667
1006031.25959.6516266.411.173930.41184.248.50.4684848.8933
1006156.251059.6516268.810.939130.647984.248.50.4684848.5933
1006218.751068.3508256.810.939130.174184.2490.4684849.0867
1006343.751168.3508260.410.939130.647984.249.50.4684850.0733
10063751168.350825810.939130.884884.2500.5270448.96
1006531.251268.350825811.134831.121784.2500.5465651.5533
1006593.751268.3508255.611.134831.358684.250.50.5660852.0467
1006718.751368.3508260.411.134831.595584.250.50.585651.6
1006781.251368.3508260.411.173931.832484.250.50.5660852.08
10068751368.3508255.610.978232.306284.2510.4684852.8
1006968.751468.350825210.978232.306284.2510.48853.52
1007031.251468.3508250.810.978232.069384.2510.5075254
1007156.251579.5355249.611.017432.306284.251.50.5075254.96
1007218.751679.5355253.211.056532.7884.251.50.5075253.9
1007312.51679.5355248.411.056532.54318651.50.5075254.6
1007406.251679.535525210.743532.543186520.3708855.3
1007468.751779.5355248.410.743532.7886520.3708857.36
1007531.251779.5355250.810.782633.016986520.390457.84
10076251779.535524610.782633.253886520.390456.9333
1007718.751879.5355253.210.704333.964586520.3513657.6333
1007781.251879.5355249.610.704333.490786520.3513659.76
1007906.251888.2347250.810.665233.964587.8520.3318460.72
1007906.251988.2347249.610.665233.964587.8520.3318459.0333
1007968.751888.2347248.410.626133.964587.8520.292861.2
Old Jun 6, 2014 | 10:35 AM
wreckleford's Avatar
I think that since you are running SD the relationship between load and torque would not necessarily hold as load is an artificial value. Although it seems to corelate pretty well in your case. I guess the better you setup up your VE maps the better it will relate.
From my experience peak load equates to lowest timing unless you are deliberately trying to reduce loads on the engine under spool-up. I would expect that you can increase timing quite a bit in the 5000 rpm range.
Old Jun 6, 2014 | 11:21 AM
I kind of thought the same thing since it is SD and "load" is just kind of a calculated value and not the actual load of the engine. My 2D VE map is kind of awkward but I wanted a normal looking fuel map.
If I go 100% throttle at 3krpms, this turbo will hit 27psi@~5000rpms ( if that's what I'm targetting ), and I always understood that as what people refer to as peak tq, which on E85 needs to be anywhere from 0-4*, and this is a 100% stock longblock. I've been running it this way for about 10k miles now. I just keep revisiting the tune and starting over each time so I can practice and refine my skills/techniques.
Old Jun 6, 2014 | 12:30 PM
420a-t's Avatar
When I had my fp black setup I had it set on a mbc and watched for peak load (airflowperrev on ecmlink, what I'm using), or peak torque. At that point on my bottom end I was around 0-1 degree. I wouldn't go as high as 4 degrees on a bottom end for sure. I was scared at 2-3 degrees. However I was targeting 37-38lbs as my max boost.
An ebc is awesome to help save a bottom end from a smaller turbo and huge torque spike. Once I put that on, it spoiled about 500rpms slower which is exactly how I wanted it setup.
Old Jun 6, 2014 | 12:34 PM
Indeed! Before this log I was targeting 400tq at 5k rpms and it would flatline, if you look you'll see my wastegate duty cycle slowly climbing up. I target 27psi then have it taper up to 33-34.
tribe
Dec 10, 2006 05:27 PM
Mad_SB
Jun 23, 2006 06:56 AM
CBRD
10
Apr 24, 2006 12:18 PM
rraulston
28
Sep 21, 2005 09:55 AM
SlowCar
10
Aug 4, 2005 07:29 PM
