AFR wierd change from heating
Old Aug 15, 2014 | 09:03 AM
KameloT's Avatar
Hello!
I have the next promblem :
On the normal (not a cold ! ) car the AFR is more reach , than after a few drag or roll race.
i.e. on a hot car AFR poorer and closer to AFRmap.
The difference is around 0.3 .
Evo 9 Speed Density
Ignition Project coils
Denso Racing IKH27 sparks
Water/Methanol Injection
Are there any thoughts as to achieve stability?
Thank you!
Old Aug 27, 2014 | 04:13 PM
okevolutionVIII's Avatar
I do know that the hotter the IAT, the richer the tune will be. This counteracts knock that could be happening with lean AFRs in hot weather. It's adjustable with Tephra V7 if you want to tamper with something that may save the engine. The water/meth injection might be something causing this as well.
lancerrally45
May 31, 2016 11:09 AM
ms32evoixmr
May 25, 2015 02:21 AM
jameswwt
Apr 23, 2015 06:37 PM
mt057
Feb 18, 2011 12:15 PM
EriCS
Jun 18, 2010 03:16 PM
