Fic 850
Old Aug 22, 2014 | 09:16 AM
GeoMitsu's Avatar
Fic 850
Hello Everyone,
I had 950CC PTE injectors and suddenly one of them wassquirting instead of spraying/pulverizing fuel, tried to clean them withultrasonic machine but in vain, so I decided to get new ones.
So I bought FIC 850CC low impedance injectors.
The time to get them (three weeks), I installed the stockinjectors and my fuel trims were zeroes.
I’ve just installed the new injectors I tried every suggested values on the net for the latency and scaling starting from Merlin 1.7 to some other values that I found, but in vain, my STFT is always 24.
I checked for air leak ----- nothing
below the last result I reached
FuelTrim_Low 2.34375
FuelTrim_Mid 4.6875
FuelTrim_High 0
FuelTrim_InUse 2.34375
O2FeedbackTrim 24.8046875
If I leave it at idle for some time the FT in use will reach a value above 12
Your suggestions are highly appreciated.
Thanks
Old Nov 14, 2014 | 06:12 AM
GeoMitsu's Avatar
To all of you who has bought new FIC 850CC, you can find attached the latency and scaling table that worked perfectly for me.
These trims are stabilized for more than 60 Km.
STFT :-2%
MDFT :2%
Scaling 770
Latency:
4.6875-----3.312
7.03125-----2.424
9.375-----1.68
11.71875-----1.296
14.0625-----1.08
16.40625-----0.912
18.6767578125-----0.816
Old Dec 5, 2015 | 04:52 AM
GeoMitsu's Avatar
To share my experience:
Less black smoke on acceleration with great engine response below are the values
Battery voltage
4.6875
7.03125
9.375
11.71875
14.0625
16.40625
18.6767578125
ms
3.384
2.568
1.728
1.416
1.08
0.912
0.576
Scaling :790
You have to alter the :
Accel Enrich Base vs Engine Temp
91
91
88
50
25
15
and:
Accel Enrichment
1.234375
1.234375
1.3359375
1.3359375
1.3359375
1.3359375
1.3359375
1.3359375
1.3359375
1.3359375
And Async Accel vs Coolant Temp Adder (Main)
42
35
31
31
27
25
10
Low fuel trim: +3%
mid fuel trim: +3%
Cheers
Fast_Freddie
Oct 30, 2023 01:56 AM
mrfred
Aug 14, 2023 11:03 AM
Raceghost
May 5, 2020 01:03 AM
teribble
Jan 31, 2017 08:22 AM
billj76
Nov 21, 2016 10:00 AM
