no spark/ no fuel after rebuild.
Old Nov 18, 2016 | 01:34 PM
billj76's Avatar
Finished up my rebuild on my 03 8 after the balance shaft belt failed. No spark but have power up to the coils but none after. The injectors are pulsing but the plugs are dry. I've checked the fuses, new crank sensor, made sure cam position reluctor was large vain down. The car ran fine prior to this.
help please.
Old Nov 18, 2016 | 09:10 PM
4b11slayer's Avatar
What else was done? Reflash?
Old Nov 18, 2016 | 09:44 PM
TexasLT4's Avatar
Start checking grounds.
Old Nov 19, 2016 | 03:03 PM
billj76's Avatar
already did everything is strung right.
Old Nov 19, 2016 | 03:04 PM
billj76's Avatar
just rebuilt everything is the same as when I tore it down.
Old Nov 19, 2016 | 03:48 PM
4b11slayer's Avatar
Mechanical timing is good?
Old Nov 20, 2016 | 01:31 PM
TexasLT4's Avatar
Make sure they have a good connection. Sometimes when you tear everything down for a build, dust/dirt/corrosion and other things can build up where grounds previously were. Gotta make sure all those surfaces are clean.
Old Nov 21, 2016 | 07:14 AM
billj76's Avatar
After back tracking a bit, Ive found my mistake. I've managed to put the crank sensor on backwards. I thought for sure I double checked. Flipped it around and it started right up.
Old Nov 21, 2016 | 10:00 AM
TexasLT4's Avatar
Cheap fix!
okevolutionVIII
16
May 31, 2014 10:45 PM
philamthebest
Jul 18, 2012 03:02 PM
VRamirez2004
16
Oct 6, 2008 11:18 PM
kansaslancer02
Lancer Troubleshooting
33
Feb 6, 2007 03:53 PM
SEEYA
26
Jul 7, 2006 09:02 PM
