96530706 ic sprayer
Old Aug 27, 2014 | 06:05 PM
92LaserRs's Avatar
96530706 ic sprayer
Has anyone gotten this to work on this ROM? I have screwed with it and the settings for days now with no luck.
Old Aug 27, 2014 | 08:54 PM
wreckleford's Avatar
The tephra spray on knock works for me.
Old Aug 27, 2014 | 09:55 PM
jedibow's Avatar
You sure about that?
Mine has never worked since converting from 94170015???
Someone figured out how to rewire it, as the rom address points to the power steering actuator?
I can't remember what the thread was titled however, I will search and see if I can find it
George
Old Aug 28, 2014 | 06:34 AM
92LaserRs's Avatar
Not to confuse things but im tying this into my meth system. I want to use the ic relay control to disable the meth under a set mph. Sort of the inverse of how it sprays until max mph. Simple relay handles that.
The problem is i cannot get it to activate the ic relay control pin no matter what i do with the settings. The only one i didnt mess with was coolant temp and im wondering if those made be in C and not F as labeled.
I can switch it to auto mode and get a lit IC light, but the output pin never goes to ground or changes state.
Old Aug 28, 2014 | 08:54 AM
I also use it to control my meth pump, with V7 9653. There is an issue with pin assignment now that I think about it. I believe 9653 uses pin 55 for the intercooler spray while the USDM ROMs and the USDM cars are wired for pin 57 as the intercooler spray.
Old Aug 28, 2014 | 05:24 PM
92LaserRs's Avatar
Ah ha! I was using 57, ill have to try 55 tomorrow. Thanks man, ill post back the results You got me curious so i did some digging and found this.
http://www.4gtuner.com/topic/6740-ev...eted/?p=195471
Old Aug 28, 2014 | 11:11 PM
jedibow's Avatar
Correct thank you Sir
Old Aug 29, 2014 | 10:07 AM
92LaserRs's Avatar
That pin switch did it! Thanks guys.
SmurfZilla
Aug 16, 2015 03:50 PM
Yme
13
Jul 1, 2014 01:31 AM
hiner005
12
Jun 28, 2014 11:32 AM
Speedlimit
For Sale - Miscellaneous Automotive
Jun 24, 2014 08:22 AM
