Flames Throwing Tune with EcuFlash
Old Oct 1, 2014 | 03:21 PM
foxbat's Avatar
This is not anti lag, it's just pops'n'bangs through -ve timing & perhaps activating SAS. It has no effect on the turbo, it might increase EGTs though
Anti lag is different, it might affect the turbo since the turbo would be spooling all time achieving positive boost in between shifts, but on the other hand it's switchable on all aftermarket ECUs so you won't have it on all the time.
Old Oct 7, 2014 | 10:24 AM
GravityKnight's Avatar
I'm assuming the tephra uses fuel cut for no lift shifting like it does with LC? I haven't tested it out personally.. just LC. A mod'd rom I used on my subaru project allowed for fuel or ignition cut for both LC and NLS. Ignition cut is violent but gives all the banging, (literally made people duck...) and fire anyone could ever want. Silly. But fun. Dropped very little boost between shifts on a 2.0 w/ a super hx 40 though.
Old Oct 8, 2014 | 11:47 AM
GregM's Avatar
The Ceddy rom is being set up so it can run true anti-lag. I assume a donation to Lee on geekmapped would get you going.
Old Oct 8, 2014 | 01:55 PM
211Ratsbud's Avatar
Try drilling out the manifold holes and not just the banjo bolts. I'm sure you can increase turbo speed with sas but one thing I haven't tried when I had it working with my vipec was drilling the manifold. Mostly because I was too lazy. However this will not increase intake manifold boost just airflow from the turbo and it gets bled into the exhaust ..
I have proof of a negative timing regime on a stock ecu increasing airflow with no sas. I logged maf Hz under both conditions ..and overlayed them..
Old Oct 9, 2014 | 12:36 PM
maximusnz's Avatar
after seeing what a evo 5/6 can do with the ceddy rom, I've always wondered if there was a evo 7/8/9 equivalent rom that can do the same, yes tephra in some cases can be better than ceddy but what I like about ceddy over tephra is that you can set up launch control on the ecu much easier. well that's my opinion lol
anyone here able to make a ceddy rom work on evo 7/8/9 ecu lol
Old Oct 9, 2014 | 12:55 PM
GregM's Avatar
Lee on Geekmapped was playing with the 7-9 rom as well. Jump on Geekmapped and take a look.
Old Oct 9, 2014 | 10:38 PM
stunt2's Avatar
what exactly does it can ? compared to tepra roms
Old Oct 11, 2014 | 07:06 PM
CDrinkH2O's Avatar
Launch control is easier to set up = flames are easier to make
Old Oct 12, 2014 | 03:41 PM
211Ratsbud's Avatar
Flames don't mean force on the turbine wheel though.
If you see the flame it's the stuff that didn't turn the exhaust wheel.
Old Apr 21, 2015 | 01:14 PM
evobad's Avatar
Hi what do you mean when you say drill out the manifold? I've already done the banjos.
Old Apr 27, 2015 | 08:00 AM
pug206's Avatar
EvoIX -20 degrees and oem bov
Old Apr 27, 2015 | 08:09 AM
pug206's Avatar
itrdc5
May 6, 2017 08:33 PM
Panamaniac
Nov 2, 2016 01:01 PM
ak47po
Sep 29, 2016 11:51 PM
awdxftw
Evo X Dyno Results
14
May 2, 2016 08:29 PM
bnr34rb26dett
Aug 30, 2015 02:28 PM
