Launch control, detonation, and spark plug failures
So I went to IFO this weekend and had a total of 3 spark plug failures. I believe this is from detonation while on 2 step. I have never had a failure any other time and my launch control has a spot of 11 counts of knock
. I have tried changing timing and fuel and the spot will not go away. Currently on -6* timing, AFR is roughly 10.5, and RPM is 6000. Any advice on how to get the knock down so im not destroying plugs?
-Nick
. I have tried changing timing and fuel and the spot will not go away. Currently on -6* timing, AFR is roughly 10.5, and RPM is 6000. Any advice on how to get the knock down so im not destroying plugs?-Nick
Yeah my transitions are smooth, the bad knock spot I have is while the turbo is spooling. I really need to figure this out so I can actually launch the car and not kill my plugs lol
How fast is your boost spooling up?
I wonder if your load calc isn't unable to keep up.
Check out this thread:
https://www.evolutionm.net/forums/09...-solution.html
It was topical for Ralliarts, due to their small, fast-spooling turbo.
The tuning item here was "Load Ramp Rate #1".
Also, be aware that having fast logging was crucial to spotting this thing in the first place. Give "RAX Fast Logging" a try, if you haven't already. It's got the key load-calc input items defined and ready to roll.
Hope that helps.
Rich
Hope that helps.
Rich
Hope that helps.
Rich
Hope that helps.
Rich
Magrud3r
Sep 25, 2014 06:22 PM
AWDBus
Dec 8, 2011 11:01 PM
QAT-R
Aug 31, 2006 11:05 PM
