88590715 - Off throttle lean spike
Old Dec 23, 2014 | 05:32 PM
tsitalon1's Avatar
Wondering if I could get some help.
I'm using 88590715 with MAF and for the most part everything is flawless, the only problem I'm seeing is a brief 2-3 second lean spike immediately after cruising when I lift off the throttle. AEM drops to 17-18 and car audibly struggles for a few seconds as the ecu compensates.
I'm trying to find the table that controls the ISCV as I lift off the throttle as I believe that may be the one I need to adjust but I'm just taking a wild guess.
Would I need to adjust the "ISCV Demand TPS Adder" tables?
Old Jan 1, 2015 | 06:30 AM
evo8426's Avatar
The car should go lean if you let off the throttle in the 2,000-4,000 range.
Old Jan 4, 2015 | 10:36 AM
tsitalon1's Avatar
Yes, but with the A/C on, it goes lean enough to almost stall and blip the oil light on the dash. With A/C off it does not.
It's a minor inconvenience but one I notice. Adjusting the "ISCV Demand TPS Adder" tables" slightly did not improve the issue, though I admit I may not have changed that table "enough".
jtbell86
11
Aug 1, 2020 09:23 PM
turboimpala
Oct 27, 2011 08:52 AM
steven121
Lancer Aftermarket Forced Induction Tech
19
Jul 8, 2011 07:07 AM
LANCEREvo9MR
E85 / Ethanol
11
Sep 30, 2009 07:35 PM
LANCEREvo9MR
Sep 20, 2009 09:54 PM
