New to ECU flash need a little help
Old Jan 2, 2015 | 08:19 PM
FstAsVR4's Avatar
I'm in the process of tuning my 2.4 LR with a 6266 on her with the factory ecu. I have been trying to get my computer to talk to my FID 2000s but it isn't working at all I have tried pretty much everything that I have read but still nothing works. Today I put in some 1250s that I had lying around and now the computer communicates with them just fine. Does anybody else have that same issue or am I just doing it completely wrong? The injectors are high impedance and I did bypass the injector resistor box and that did nothing. Any help is appreciated.
Old Jan 2, 2015 | 08:57 PM
okevolutionVIII's Avatar
What numbers did you enter for scaling and latency compensation?
Old Jan 3, 2015 | 10:31 AM
FstAsVR4's Avatar
1600 scaling tried the latency that came with injector then changed the scaling found on here for those injectors and still wasn't able to control fuel
Old Jan 4, 2015 | 01:23 PM
CDrinkH2O's Avatar
Post a screen shot of the settings you have for scaling and latency. Some questions to help us diagnose the problem for you.
Are you running pump gas?
Is the problem that you cannot start the motor?
What is the fuel pressure at the rail? Should be 43.5 psi
If you cannot start it, is it too rich (fuel on pistons, plugs fouled), or too lean?
The ID2000's are very responsive to changes in latency. Check the battery voltage while cranking to see where on the latency curve you are operating and focus on changing latency at that voltage.
Increase latency if too lean, decrease if too rich
Previously posted "good" settings for ID2000's on 92 gas:
Scaling: 1624
Latencies (very responsive):
V msec
9.38 - .936
11.72 - .672
14.06 - .504
16.41 - .384
AWDTFTW
Feb 8, 2014 02:17 PM
Grip Master
Feb 2, 2013 06:21 PM
btmboards
Mar 13, 2012 06:32 PM
thebluesky
Mar 12, 2012 02:20 AM
4mypsp
Apr 30, 2010 12:27 PM
