Need a little direction on setup pre ecu flash (gurus please chime in)
Old Mar 10, 2012 | 03:04 PM
thebluesky's Avatar
Sorry if my questions have been covered before. I'm sure they have, but both the search and google are giving me conflicting answers. I am considering going from stand alone to ecu flash, but am not readily finding the answers I'm looking for.
First of all, I have heard that it is possible to replace the front o2 sensor from stock to a wideband. I am wanting to use the LC-1 which is currently wired directly to the ecu. Will the stock ecu flashed be able to read it so long as I convert the signal to 0-1v, or do I have to use the stock front 02 sensor?
Secondly, I am currently running speed density. I recognize that my current IAT sensor will most likely not work in conjunction with ecu flash and will need to convert to the GM IAT. Bearing that in mind, do I wire the GM IAT to the MAF harness (like most stand alone IATs), or does it need to be wired differently?
Old Mar 11, 2012 | 12:09 PM
drifterific's Avatar
From what I understand when on the stock ecu you Must keep the front o2 sensor. You can replace the rear one by the cat but have to keep the stock one. You can wire your IAT into the MAF harness or directly into the ECU. SpoolingUp sells the harness for the MAF connection on their website.
http://www.spoolinup.com/
Old Mar 12, 2012 | 02:20 AM
vd's Avatar
vd
As for the frontO2 - you can wire the simulated 0-1V signal from your WBO2 (if it has such feature) into the ECU instead of frontO2.
mrfred
Oct 8, 2023 04:45 AM
95630706
Oct 8, 2017 08:12 AM
SnailSpeed
Jan 1, 2017 06:52 AM
golgo13
Mar 10, 2010 09:14 PM
evoblack9
AEM EMS
Sep 28, 2005 05:34 AM
