Thoughts on things to change in tune?
Old Jan 24, 2015 | 03:28 PM
AWDb00st239's Avatar
My car is a IX that was tuned with the wrong spark plugs i it, NGK BKR5E to be exact. Previous owner, but still should have checked that before tuning it. So too short, 2 heat ranges too hot, and gapped at 0.040. Lesson learned, maintenance before performance mods.
Anyways the tuner is about 4 hours away since there are no evo shops here, and with the stock IX plugs in the car, I am getting 8+ counts of knock around 5500 and beyond. And 3 counts of knock consistently during spool. Any thoughts on what to adjust? I'm thinking timing. 1 step colders don't make any change.
If a full retune is best, I appreicate that input also. Thanks.
For the lulz.
Old Jan 24, 2015 | 04:24 PM
hutch959's Avatar
i would assume your afr's would still be ok.
probably just need to pull timing.
logs?
Old Jan 24, 2015 | 06:45 PM
I'll pull some logs and put them up here, I was worried to do a full pull since the TephraMod knock cel flashes fast starting at 5500 which is set to 8 count. Lift off knock as well, I don't actually hear it pinging though, so its strange to me.
Old Feb 7, 2015 | 01:26 PM
Evilution226's Avatar
I do not see it causing that much problem. What are they gapped to now? Anything else change?
Welcome2GoodBur
Feb 17, 2017 08:49 AM
Welcome2GoodBur
Feb 10, 2017 08:01 PM
R0ME0
22
Aug 13, 2009 10:40 PM
